HRT wrote:If its all gears going like that at once then I wouldn't imagine it to be synchros. Not very likely they would all go bad at the same time. Sounds more like the clutch is getting pretty worn or not quite disengaging completely, slave cylinder could be leaking a little or some air got into the system or something.
Akane wrote:Your gearbox is stuffed man, stop driving your car as if it's a race car, it's just a MR2 afterall. Sell it, get yourself a Nissan.
If you don't drive a Nissan, you don't know what you're missin'
solitaire wrote:Is that why your trying to swap yours for an ae86?
Akane wrote:solitaire wrote:Is that why your trying to swap yours for an ae86?
Hey shhhhhhhhhh! It's coz I can't find a CA18DET for mine! And the 3S-GTE RWD conversion kit is sold to someone else, I was too late.
TOYROTA wrote:do you think i could be a worn selector linkage or cable?
