hard shifts
hard shifts
Postby avinesh » Wed Nov 01, 2006 6:53 pm
i was driving home from botany today an at the lights my gears sort of went stiff it was harder to drop it in 1st while stopping at the lights an then engaging second took a bit of effort an also third an fourth slowly..... gears dont crunch or anything just really hard to shift only sumtimes an sumtimes its really easy to shift into gear..... i checked the gear box oil an it looked black in color so im changing it tomorow with redline mtl gear box oil..... i have already checked the clutch fluid level an its at its fullest..... do you guys think a worn out oil would do this i changed the oil 2-3 months ago, i used castrol vmx oil.....
avinesh
Postby Adydas » Wed Nov 01, 2006 7:35 pm
Sounds like the syncros are wearing, if you blip the accell as your preparing to change down at lights does it change easyer? if so Yup Syncros.
Chances are, its that and only that.
Try and rev match as you change down, some advice i took from somone, helps get into gear faster to engine brake ( if thats your style of driving ) as well as prevents some of that crunching it into gear wear on the syncos hopefully causing them to last a tad longer.
Adydas
Postby Emperor » Wed Nov 01, 2006 7:39 pm
My RX7 did that with the MX5 gearbox, hard to shift up gear, but it crunched like a mofo..
Just rev match when changing and it was a bit easier.
Now being rebuilt tho :D
Emperor
Postby Lloyd » Wed Nov 01, 2006 7:47 pm
If its all gears going like that at once then I wouldn't imagine it to be synchros. Not very likely they would all go bad at the same time. Sounds more like the clutch is getting pretty worn or not quite disengaging completely, slave cylinder could be leaking a little or some air got into the system or something.
Postby avinesh » Wed Nov 01, 2006 8:14 pm
HRT wrote:If its all gears going like that at once then I wouldn't imagine it to be synchros. Not very likely they would all go bad at the same time. Sounds more like the clutch is getting pretty worn or not quite disengaging completely, slave cylinder could be leaking a little or some air got into the system or something.
box is not crunching an the clutch was changed 2 months ago an even when the car is turned off the gears are still hard to engage..... but once you force it in it become easier an then hard again after a while
avinesh
Postby eritate » Thu Nov 02, 2006 1:07 am
I think its the master or slave cylinder.
Does the clutch pedal have much slack? and does it feel a bit sticky when u push it in or release it ?
Mike
I am a timewaster. Ignore anything I say
eritate
Postby avinesh » Thu Nov 02, 2006 8:54 am
eritate wrote:I think its the master or slave cylinder.
Mike
no the clutch pedal is normal just like before.....
avinesh
Postby Akane » Thu Nov 02, 2006 9:11 am
Your gearbox is stuffed man, stop driving your car as if it's a race car, it's just a MR2 afterall. Sell it, get yourself a Nissan.
If you don't drive a Nissan, you don't know what you're missin'
Postby solitaire » Thu Nov 02, 2006 1:21 pm
Akane wrote:Your gearbox is stuffed man, stop driving your car as if it's a race car, it's just a MR2 afterall. Sell it, get yourself a Nissan.
:lol: Is that why your trying to swap yours for an ae86?
AE92, KZJ120, KDJ120
solitaire
Postby Akane » Thu Nov 02, 2006 2:32 pm
solitaire wrote: :lol: Is that why your trying to swap yours for an ae86?
Hey shhhhhhhhhh! It's coz I can't find a CA18DET for mine! And the 3S-GTE RWD conversion kit is sold to someone else, I was too late.
Postby Lith » Thu Nov 02, 2006 2:37 pm
WTF? Why on gods green earth would you want to put a 3SGTE into an S13???? BLURGH!! <runs away>
Lith
Postby Akane » Thu Nov 02, 2006 3:30 pm
Got a spare one lying around. Why not?
It'll be combining Toyota reliability :roll: and Nissan's great design :lol:
would it be
Postby TOYROTA » Thu Nov 02, 2006 4:27 pm
do you think i could be a worn selector linkage or cable?
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Re: would it be
Postby aesc » Thu Nov 02, 2006 4:59 pm
TOYROTA wrote:do you think i could be a worn selector linkage or cable?
Yip I would say your cable is gone or atleast is on its way out. Had the same symptoms in my ae101, the selector cable had broken
EX AE101 owner
2013 Ford Focus ST
aesc
