Blacktop pistons into 16v bluetop
Postby TOYROTA » Thu Nov 02, 2006 3:07 pm
will pistons from a blacktop 20v fit into a bluetop 16v bigport??
im thankful for ur feedback.
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby RedMist » Thu Nov 02, 2006 3:09 pm
No, different flycuts for valves and different sized gudgeon.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
bugger
Postby TOYROTA » Thu Nov 02, 2006 3:24 pm
if thats the case does anyone know where i can get a set of aftermarket high comp pistons and rods to suit a bluetop 16v from??
Curre3nt rides-
TOYROTA
Postby evil_si » Thu Nov 02, 2006 3:34 pm
id look at skimming the head to raise compression, and running a trd high comp head gasket,
after market rods and pistons ud be looking at leadt a couple of grand
could look at high comp redtop pistons, but i dont think they will fit bluetop rods without machining, and redtop rods wont fit bluetop crank :?
evil_si
WOT BOUT?
Postby TOYROTA » Thu Nov 02, 2006 4:07 pm
what about ZE pistons i know they would lower compression but could you machine the head down enough to raise compression to a n/a requirement?
Curre3nt rides-
TOYROTA
Postby Distrb » Thu Nov 02, 2006 4:10 pm
could you not change the rotating assembly redtop smallport items to allow you the bigger gudeon pins etc.. and shave the head for a little more compression
but then again, for the amount of p1ssing around and $$ spent you could put redtop in there..
Distrb
Regular Poster
new to me
Postby TOYROTA » Thu Nov 02, 2006 4:18 pm
i havent done that much in depth engine work, the only motor i have pulled down that far was a 4k.
i have been ringing around today and got some prices for parts i want to put in my motor.
S/top quad throttles $150 i brought these from a wrecker
B/top pistons, rods, bearings and gasket set $950
HKS cams $575 each
HKS cam gears $295 each
HKS 1mm metal head gasket $309
HKS valve springs $195 for the set
price wise i didnt think all that stuff was that bad
Curre3nt rides-
TOYROTA
Postby CAMB01 » Thu Nov 02, 2006 4:41 pm
You can get a TRD metal headgasket that is thinner for a third of the HKS headgasket price.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
where
Postby TOYROTA » Thu Nov 02, 2006 4:44 pm
where bouts would i get 1 of those cambo?
Curre3nt rides-
TOYROTA
Postby CAMB01 » Thu Nov 02, 2006 4:47 pm
Email Mr Revhead, they come in two thicknesses, 0.8mm and 0.5mm.
CAMB01
Re: Blacktop pistons into 16v bluetop
Postby NZ_AE86 » Thu Nov 02, 2006 7:09 pm
TOYROTA wrote:will pistons from a blacktop 20v fit into a bluetop 16v bigport??
Can be done, works well.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
NZ ae86
Postby TOYROTA » Fri Nov 03, 2006 9:41 am
hey NZ AE86 how did u make it work?
Curre3nt rides-
TOYROTA
Postby TRD Man » Sat Nov 04, 2006 11:25 am
I have 2 sets of TRD forged pistons here. Both new.
TRD Man
Postby CAMB01 » Sun Nov 05, 2006 11:04 am
What compression are those TRD pistons?
CAMB01
Postby vvega » Sun Nov 05, 2006 12:41 pm
anything can be done just make sure you ahave wad of cash relative to the imposibility of the misson
vvega
Postby SpeedRacer » Sun Nov 05, 2006 5:19 pm
so this would be ok for a redtop?
rod length is same
crank is the same
fly cuts dnt really matter because they are non-inferance?
so would using b/t pistons and rods in a red top work?
Sinister Sleeper 35
SpeedRacer
Postby AceSniper » Sun Nov 05, 2006 6:32 pm
Dont use the rods!
pistons can work but if you timming gets fkd you will bend stuff
AceSniper
HOW MUCH?
Postby TOYROTA » Tue Nov 07, 2006 9:15 am
hey trd man how much do you want for those pistons?
Curre3nt rides-
TOYROTA
Postby ee904age » Sun Nov 12, 2006 10:54 am
I've got silvertop rods and pistons in my bigport redtop, its not running yet but it all fits well, just becomes an interferance engine.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Users browsing this forum: No registered users and 22 guests
