vvt
vvt
Postby matt9ball » Sat Nov 11, 2006 5:53 pm
ok so i have searched but dont really get it.
im positive vvt is not working on my car have put 12 v to solenoid and the engine does not change.there is also no 12v power going to solenoid at idle or reving!
the vvt pulley has jus been replaced for a second hand 1 as other 1 was making a huge clicking sound as shown on revheads test FAQ.
so i dont have power to solenoid and when 12v put on it no change at all!?
hooked up vvt light and it constantly stays on also.
this is a s/t conversion and never seen it running before but i was sure it had 12v running to solenoid when conversion was being done.
please help!!!
thanks guys :cry:
matt9ball
Postby slighty_sykotic » Sat Nov 11, 2006 6:56 pm
how are you putting 12v to it? you are putting 12v to one side of the solinoid, and putting the other side to the negitive of the battery arn't you?
--Sykotic
slighty_sykotic
Postby matt9ball » Sat Nov 11, 2006 7:00 pm
taking plug off solenoid and running 1 wire from battery postive to 1 of the connection points on solenoid and running another wire from negative on battery to other connecton point on solenoid.
thats correct? :oops:
thanks
matt9ball
Postby Mr Revhead » Sat Nov 11, 2006 11:43 pm
you are making sure you have + to the right side arnt u?
Postby sergei » Sun Nov 12, 2006 12:06 am
BTW it is really easy to fry output transistor if not carefull ($5 darlington)..
Postby matt9ball » Sun Nov 12, 2006 3:52 pm
thanxz sergei
i reckon i might have.how can i check if i have?and where can i get 1?still has vvt output signal when unplugged at solenoid as i have a vvt lite.
matt9ball
Postby matt9ball » Sun Nov 12, 2006 3:55 pm
revhead
i have bn using + to the right hand side connection on solenoid point looking at solenoid.
matt9ball
vvt
Postby RevolutionStarlet89 » Sun Nov 26, 2006 3:22 pm
yeh my vvt isnt working either, connected a couple of wire from the battery to the solinoid and could hear the vvt click on, but dosent work when im driving. I have no idea how to fix it or whats wrong with it, there is power from the clip that attaches to the solinoid.... So that leaves me thinking that the problem is between the ecu and the solinoid, any1 got any ideas?????
SKoty
Current Current Ride: 1992 Toyota Trueno Gt Apex
Ex-Current Ride: 1991 Toyota Levin Gt Apex(Written Off)
Previous Ride: 1989 Toyota Starlet XL
RevolutionStarlet89
Postby AceSniper » Sun Nov 26, 2006 3:35 pm
might be the ecu output has burnt out
AceSniper
Postby RevolutionStarlet89 » Sun Nov 26, 2006 6:58 pm
if i did have a ecu burn out wouldnt the power output stop??????
SKoty
RevolutionStarlet89
Postby AceSniper » Sun Nov 26, 2006 7:08 pm
+12v is from efi relay, ecu sends out a ground
AceSniper
Postby RevolutionStarlet89 » Mon Nov 27, 2006 3:26 pm
sergei wrote:BTW it is really easy to fry output transistor if not carefull ($5 darlington)..
what is this output transistor u are talking about? and where do i find it?
SKoty
RevolutionStarlet89
