Power FC for ST202 ?
Postby Wolf_Tm250 » Mon Nov 13, 2006 2:56 am
Hello,
I'm looking for a Power FC for a friend's ST202...
but I'm not able to find it for this car....
Would it be possible to fit the Altezza 3SGE one ?
Thank you.
Wolf_Tm250
Wolf_Tm250
Postby Adydas » Mon Nov 13, 2006 10:08 am
Youl have a hard time doing so.. theres a guy on the shore whos apparantly pritty good at fitting pfcs into cars they dont belong.
try him
Adydas
Postby Boosted_162 » Mon Nov 13, 2006 1:56 pm
Look at his location Cliff, dont think someone on the shore can help :lol:
Re: Power FC for ST202 ?
Postby RomanV » Mon Nov 13, 2006 2:08 pm
Assuming it's a gen 3 3SGE.... Then it's easy as to fit pretty much any ECU.
If it's a gen 4 'redtop' 3SGE, then your selections are a lot more limited. :?
There's a japanese company called 'brashboy' that modifies Altezza ECUs for use with the ST202.
Also C-one does the same thing, google either of them and you'll find the ECU you're looking for, which will be plug and play. 8)
Postby Wolf_Tm250 » Tue Nov 14, 2006 2:48 am
Boosted_162 wrote:Look at his location Cliff, dont think someone on the shore can help :lol:
:lol:
This is not a big problem... if you can find me an already modded Altezza's one... :wink:
Thank you guys...
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Tue Nov 14, 2006 2:53 am
RomanV wrote:Assuming it's a gen 3 3SGE.... Then it's easy as to fit pretty much any ECU.
The fact is that on Ebay you can find Altezza's PFC at a VERY low price... lower than ANY ecu... :wink:
ST202, so I think it's a 3rd gen.... "silvertop" ??
I know them.... but they are really expensive... more than a reprogrammable ecu...
Thank you.
Wolf_Tm250
Wolf_Tm250
Postby Alex B » Tue Nov 14, 2006 1:35 pm
ST202 also came with redtop.
Postby Wolf_Tm250 » Tue Nov 14, 2006 1:44 pm
pyro_sniper2002 wrote:ST202 also came with redtop.
I know !
SS2 and SS3 Beams engined...
I only wanted to know if the "normal" 3SGE 175 hp is called "silvertop", has it has a silver valve cover.
Wolf_Tm250
Wolf_Tm250
Postby Alex B » Tue Nov 14, 2006 1:49 pm
Nope its not called that its just a gen 3 3s-ge. Get one and 2 3s-ge's also have "silver tops". Only engine by toyota referred to as a silver top is a 20V 4a-ge.
