Guard rubage?
Guard rubage?
Postby ke25sr » Sun Nov 19, 2006 5:25 pm
In my coupe i got a TE71 disc brake rear end. Its a hell of a lot wider than the stock item.
Leafs have been re set & a extra leaf added i also got new gas shocks.
It rubs quite badly on bumps & corners.
i no there is several ways to resolve this i just want to no what you guys think is the best?
So how would you fix it??
ke25sr
Postby Cahuna » Sun Nov 19, 2006 5:37 pm
Which point is it rubbing on, inside the wheelarch or the actual guard?
If it is the guard then you might be able to roll its edge. On both my Escort and my Corolla the guard comes down at the wheelarch and then has a flat piece approx 8mm wide going flat into the wheelarch, which caught on the tyre. If you are careful you can use a hammer to gently bend that flat piece up so that it sits flush with the shape of the wheelarch.
If it works then it is a cheap 30 minute solution, so is probably worth trying as a starting point.
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby ke25sr » Sun Nov 19, 2006 10:23 pm
i done that ages ago with the old set up worked a treat.
now im prob more looking at cutting the skins out and welding. Or rolling the guard
ke25sr
