need some help with my wagon :(
Postby fx gt » Tue Nov 21, 2006 11:02 pm
i cant seem to match the looms up
i think i need a 4afe loom but will it have the same plugs as a4age?
also how can i run a 4age on the single cam ae92 fuel sistem.i dont have the line with the permanant nut on it :|
fx gt
Postby Chickenman » Wed Nov 22, 2006 12:10 am
Was your car efi?
if not you're better off grabbing an efi fuel tank and all the fuel lines etc before you get it going and it leans out in a corner and dies.
if it is.
Ignore me.
Baby Jesus
Chickenman
I Am The Walrus!
Postby bluemaumau » Wed Nov 22, 2006 8:02 pm
do what chickenman said and 4afe and 4age looms are quite different apparently
unsure of 4af looms tho
Postby fx gt » Wed Nov 22, 2006 9:54 pm
so i can get the fuel lines out of a ae92 4 door corolla?
i presume i have the rong fuel set up as i have 3 lines near fire wall insteat of the 2 which is on the fxgt
also i have no idea what to do with the looms.i bought a fxgt dash loom to go into the wagon and have the smallport 4age loom.me thinking it would connect up it dosnt :(.what loom do u guys think i need to get?
im trying to get all the plugs near the passengers foot well connected but they dont. HELP :(
fx gt
Postby fx gt » Thu Nov 23, 2006 1:53 pm
BUMPPPPPPPPPPPPPPPPPPPPPPPPpp
fx gt
Postby Chickenman » Thu Nov 23, 2006 3:03 pm
fx gt wrote:so i can get the fuel lines out of a ae92 4 door corolla?
Any EFI one yeah, 4age or 4afe should be the same I think. Don't forget the fuel tank as you need some surge protection with efi.
fx gt wrote:also i have no idea what to do with the looms.i bought a fxgt dash loom to go into the wagon and have the smallport 4age loom.me thinking it would connect up it dosnt :(.what loom do u guys think i need to get?
The problem with carby cars is they are quite simple and totally different to their efi counterparts. I had major troubles getting a 3sgte loom to work in my corona, just takes a lot of time and a few diagrams.
Leave the original dash and wiring in there. Strip down the smallport loom so you only have what you need in the engine bay and get it running seperate to the other electronics. Treat it as a standalone aftermarket ecu running fuel, ignition fuel pump etc and you should be alright. Trust me, as soon as you start thinking of re wiring the kickpanel fusebox etc you are going to hurt yourself... they are too different to just Rambo in and fix in a day.
Baby Jesus
Chickenman
I Am The Walrus!
Postby fx gt » Fri Nov 24, 2006 1:27 pm
dAm i wish u lived in Auklnd :P
but there must be A loom i cAn get tht will conect strAight up?
fx gt
Postby fx gt » Sat Nov 25, 2006 1:48 pm
bumpp
fx gt
Postby bluemaumau » Sat Nov 25, 2006 2:26 pm
i dint do my cars loom, but from what i understand most of the work was in the engine loom not the dash, it was more a modifyn the original dash loom to fit a 4agze ecu plug, basically putting a 4afe dash loom plug onto my 4agze plug,
not sure if that helps, but you seem pretty lost lol
Postby Chickenman » Sat Nov 25, 2006 3:01 pm
fx gt wrote:dAm i wish u lived in Auklnd :P
Ha!!! I learnt the hard way :( (and still wouldn't do a carby to efi conversion without an aftermarket ecu.)
As BMM did say, you only need to adapt a few dash wires to the new ecu.
Engine check/warning light (important for fault finding etc)
Start
Ignition
Stop light
Speed sensor (need some signal, accuracy isn't so important on the blue/redtop ecu's afaik)
Have you got all the relevant diagrams etc? Be pushing shit uphill if you don't. What engine have you got exactly? tvis?
Baby Jesus
Chickenman
I Am The Walrus!
Postby CozmoNz » Sat Nov 25, 2006 3:10 pm
we all wish he lived in the north island :P
Rayne For President!
CozmoNz
Postby Chickenman » Sat Nov 25, 2006 3:18 pm
$&#$% you hippy, I was there for long enough :roll:
Sooo.... when are you leaving? :lol: :lol: :o :D
Baby Jesus
Chickenman
I Am The Walrus!
Postby fx gt » Sun Nov 26, 2006 2:15 am
4ge non tvis.is pics of plugs in the car domain link in mi sig thingy :P
fx gt
Postby fx gt » Thu Nov 30, 2006 1:52 am
so do i need to just get the plugs n cut them then connect them?
fx gt
Postby Chickenman » Thu Nov 30, 2006 9:14 am
Basically yes.
I think you should get some help from an auto electrician though dude. If you fry your ecu it aint good and I can't help you over the net and be sure you'll understand what I tell you to do. I haven't got the time sorry bud.
If I do get a chance later I'll find the pinout diagram specific to your engine and see what I can do but no promises.
Baby Jesus
Chickenman
I Am The Walrus!
Postby fx gt » Thu Nov 30, 2006 3:03 pm
cool
i may go to pikapart tomorrow and cut some plugs of a fx corolla and just add them to mine using wire connectors.it shouldnt be that hard cause its match colours up to colours on the plug isnt it?
fx gt
Postby Cahuna » Thu Nov 30, 2006 4:30 pm
Not quite colour to colour.
My car has an interior loom out of a FXZS (to match to the smallport engine loom), some of the colours are different on the two looms and there were a couple of extra wires on the interior loom that were left over as well (not required).
Definitely wait for a pinout diagram otherwise you will risk frying the ECU. You can borrow my Haynes manual with wiring diagrams for the different Corolla models for a couple of weeks if you need it, but beware that the wiring diagrams aren't the easiest to interpret!
If you got to Pick a Part make sure you note which model and engine you are grabbing the loom out of, also make sure you get the right plugs (the TVIS computer plugs are different to the smallport ones but I
think the plugs for the 4AFE are the same).
We know that four-wheel drive doesn't work in a racing car, and I proved to myself that it doesn't work very well for rallycross. I'm absolutely convinced that it has no future in rallying, either, even if the regulations allowed it. - Roger Clark (rallying legend), circa 1976
Cahuna
Postby fx gt » Thu Nov 30, 2006 4:49 pm
Cahuna wrote:Not quite colour to colour.
do u recon u could help me then?i have a non tvis red top.should i just get a FXZS loom.does it match up straight up or not?
fx gt
Postby Cahuna » Thu Nov 30, 2006 5:09 pm
No, as I said there are a few extra wires and the colours are different.
Sorry but I'm a n00b when it comes to wiring... when it came to matching the two looms on my car I just gave the car and the book to my boss and asked him to do it for me (as far as I know electricity is just smoke... it must be, because every time I blow something up it smokes! :lol: ) So no, even if I had a spare afternoon you would NOT want me touching the wiring on your car - trust me on that one :lol: :oops:
Cahuna
Postby fx gt » Fri Dec 01, 2006 3:38 pm
Cahuna wrote:No, as I said there are a few extra wires and the colours are different.
haha thts ok.
so ill get the loom u have and can i borrow ur manual?
the manual wil have all digagrams in it to connect them up???
fx gt
