Is this too dodgy?
Is this too dodgy?
Postby ollieboy » Sat Nov 25, 2006 5:12 pm
I was talking to a guy who used to work at oilchangers. He said they pump 75 litres of solvent through the engines when they clean them. I had an idea. On one of my cars the sump is really dirty and I'm pressed for time and money and need to get the car going by next Friday and moved off the property (along with all my other broken cars) so I can have a party in the backyard. Would it be fine if I poured some sort of solvent, probably petrol into the sump and turned it over by hand a couple of times to clean the inside? Or will it do something to the engine that is pretty negative?
I would pull sump off and clean it all and the block etc but I don't have time to do that and I would run oil through it until its clear but I don't have the money for oil so this was my next idea.
ollieboy
Postby Chickenman » Sat Nov 25, 2006 5:15 pm
Someone mentioned kerosene in another thread....
Easy does it though :P
Baby Jesus
Chickenman
I Am The Walrus!
Postby SUBARUCONVERT » Sat Nov 25, 2006 9:57 pm
or diesel
3ST150
SUBARUCONVERT
Postby ollieboy » Sun Nov 26, 2006 12:58 am
SUBARUCONVERT wrote:or diesel
Yeah thats good, cheaper. (I think I must be part Jew.)
ollieboy
Postby CAMB01 » Sun Nov 26, 2006 8:37 am
Put diesel in the sump and run the engine, but dont rev it.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby sergei » Sun Nov 26, 2006 9:54 am
CAMB01 wrote:Put diesel in the sump and run the engine, but dont rev it.
Do that if the engine is off LADA, it is $&#$% from factory so no harm will be done.
If I were you I would not "clean" the engine by pouring stuff in it - it will never clean anything. The effect would be that it will flake loose the sluge which will block the oil strainer which in fact will result in run bearings...
If you want to clean properly you will have to pull it apart.
Also diesel will kill your seals -> you will have major problems with blue smoke and oil leaks after a while.
Postby bluemaumau » Sun Nov 26, 2006 12:15 pm
yea sergei right imo.
fully clean it or dont
Postby ollieboy » Sun Nov 26, 2006 2:51 pm
Ok, so should I just put fresh oil in then and change it when it gets black again until its clear?
ollieboy
Postby myke » Mon Nov 27, 2006 11:55 am
ollieboy wrote:Ok, so should I just put fresh oil in then and change it when it gets black again until its clear?
no point, will be black as soon as u start the engine
Myke
myke
