Modifying ae86 diff
Modifying ae86 diff
Postby trdnut » Mon Nov 27, 2006 1:49 pm
is there anyway i could put the crown wheel of a townace or hilux into a ae86 diff.
problem is that i got a 4agte in a ke70 and i been through two diffs already, its becoming expensive!!
:roll:
trdnut
Postby Rick » Mon Nov 27, 2006 4:32 pm
Dont bother with the ae86 diff, go for a hilux diff...
Postby Jebus » Mon Nov 27, 2006 5:04 pm
Yep go hilux.
BTW 2 diffs is nothing, try 8 heads, 2 axles and a driveshaft in 8000km of street driving.
Jebus
Postby trdnut » Mon Nov 27, 2006 5:36 pm
Whots involved with converting a hilux diff to discs? whats bout the mounts and overall width?
Any particular year?
I'm fully keen on doing one just don know where to start.
trdnut
Postby trdnut » Mon Nov 27, 2006 5:37 pm
I want to keep it as stock looking as possible
trdnut
Postby l1ttle_d3vil » Mon Nov 27, 2006 6:35 pm
Jebus wrote:and a driveshaft in 8000km of street driving.
what the hell did you do to a driveshaft???
is your ke70 coil or leaf sprung in the back? either way, you'll just need to modify the mounts to suit your ke70 setup, get your driveshaft done to suit then setup the brake lines/hand brake cables.
they don't necesarrily need shortening, there are hilux diffs around that you can run fwd offset mags on fine.
Postby trdnut » Mon Nov 27, 2006 11:03 pm
i got springs at the back, so if i stripped down both diffs and put all the mounts over i shoud be sweet?
trdnut
Users browsing this forum: Bing [Bot] and 7 guests
