Removing an axle
Removing an axle
Postby Hachiroku » Tue Nov 28, 2006 10:13 am
My new diff showed up last week but i'm having a prick of a time trying to get one of the axles out :x It's a solid F series LSD from a Liteace van. I was able to pull the first one out easily by hand but the second one won't budge at all. I don't have a slide hammer. Is there anything inside the diff head that separates the two axles? ie can I put something in from the other end and try to drive it out?
Hachiroku
NAH
Postby TOYROTA » Tue Nov 28, 2006 10:23 am
there is a pinion at the diff centre that will stop you from putting anything in from the other side and pushing it out.
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby Hachiroku » Tue Nov 28, 2006 12:04 pm
Of course there is. What a ham :oops: Any good ideas for getting the thing out?
Hachiroku
Postby spencer » Tue Nov 28, 2006 12:58 pm
bigger slide hammer? if all else fails heat does the trick but bearing will be stuffed after that
spencer
Postby Silent Knight » Tue Nov 28, 2006 1:58 pm
Take 2 crowbars and apply an equal amount of upwards force from opposite sides of the half shaft. It should pop up and then you should be able to just slide it out.
Silent Knight
Postby KE25-KP30 » Tue Nov 28, 2006 3:52 pm
I've got a slide hammer I'l bring home and you can get it tonight If you'd like it. :wink:
KE25-KP30
Postby Jdawg » Tue Nov 28, 2006 10:43 pm
If you have a long handled sledge hammer or similar, heavy end down , tie it to the axle and make like a golf putting stroke, should pop the axle right out, always worked on the old Valiants :wink:
Jdawg
