offsets
offsets
Postby 79rolla » Wed Nov 29, 2006 1:48 pm
what is the diference that offsets make?
does it matter if you for example put rwd offset rims on a fwd car e.c.t
just trying to figure it out
thnx
past: AE82 FXGT
79rolla
Postby Santa'sBoostinSleigh » Wed Nov 29, 2006 1:59 pm
tires can rub on strut or stick out too far past the guards if you get it wrong
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby slonlo » Wed Nov 29, 2006 2:03 pm
Changing offset changes the stress point/angle on the wheel bearings
Wears them out faster
Also looks kinds off with huge wheels way out the guards ( off-road style)
'89 LiteACE van
slonlo
Postby Zak » Wed Nov 29, 2006 3:15 pm
It also changes alot more than most people think. If you put the wrong offset wheels on your car and a tire blows out at the front your car will violently pull to that side. It can also wear out your tires more quickily. It's more important on a FWD car rather than a RWD but it's all ways better to use the proper off set if possible.
Zak
Postby GTCRSHR » Wed Nov 29, 2006 4:40 pm
would it be better to have a wider wider off set ? or use spacers ?
appart from the fact that spacers are only certable up to 20or so mm
Nothing to see here ...
GTCRSHR
Postby Zak » Wed Nov 29, 2006 4:44 pm
At the end of the day it's not going to make much difference you'll end up with the same result. With a spacer you can use the wheel on another car if need be. But I wouldn't trust them myself :?
Zak
Users browsing this forum: Google [Bot] and 17 guests
