Wiper problems
Wiper problems
Postby xRyanx » Wed Nov 29, 2006 8:29 pm
Hey,
Am trying to remove my wipers off my ae111 to give them a repaint. Ive got the bolts off (front and rear) but cant get them any further than that. Im scared to give them an almighty whack coz im unsure if they should just pull off.
Are they just stuck and need a bit of force, or is there a special way to take them off?
ADMIN EDIT: oversized sig image removed - way too large
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $&#$% UP XRYANX!!
xRyanx
Postby bluemaumau » Wed Nov 29, 2006 8:33 pm
if youve removed the bolts, fold em up give em a wiggle and they should just come off :?
Postby xRyanx » Wed Nov 29, 2006 8:40 pm
ok cheers, ill crc them and see how i go. i guess there just seized up after staying in the same place for 11 years
xRyanx
Postby xRyanx » Wed Nov 29, 2006 8:48 pm
No luck with that. There stuck good and proper :?
xRyanx
Postby Bling » Wed Nov 29, 2006 9:03 pm
fold it up using above method, and put a "device" between the car and part of the wiper the bolt sits on, then just lever it :)
if u be gentle, it will come off easy enough
or maybe u could just tap it with a hammer side to side
Postby Santa'sBoostinSleigh » Wed Nov 29, 2006 9:22 pm
make sure you are pulling them off in the same direction of the bolt, and not on the piss. its a bit tricky due to the spring in the wiper
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby xRyanx » Wed Nov 29, 2006 9:22 pm
I went straight to the hammer idea and it still did jack. (used a rubber mellot)
Ill have another go tomorrow but for now its like i havn't removed the bolts...
:evil:
xRyanx
Postby Mr Revhead » Wed Nov 29, 2006 10:03 pm
they could well be loc-tited on.
Postby 79rolla » Wed Nov 29, 2006 10:09 pm
would a bit of crc help?
past: AE82 FXGT
79rolla
Postby Bling » Wed Nov 29, 2006 10:28 pm
so you didnt try the screwdriver idea? aka 'device'
Postby xRyanx » Thu Nov 30, 2006 1:49 pm
CRC did jack, ill try it with the screwdriver tonight.
Cheers everyone
xRyanx
Postby MrOizo » Thu Nov 30, 2006 2:52 pm
Dodgey... you should be able to lift the wiper up and be able to work it loose from light force applied from the further most strongest bit. where the arm is connected to the wiper itself.
as far as i can remember they are a splined tapered shaft and just need a little work cos they might have oxidised and all that.
be careful when playing around too. that spring in the bottom hinge where it bolts to the motor has ghot a fair whack in it when it lets go! :o
MrOizo
Toyspeed Legend
