Turbo 4AGE
Turbo 4AGE
Postby Santa'sBoostinSleigh » Thu Nov 30, 2006 8:57 am
well since just about every week there seems to be someone asking about turbo 4AGE's, i thought i'd set up a FAQ type post (ie this will be moved to the FAQ section when it has some good info in it)
DO NOT POST IN HERE IF YOU DONT KNOW WHAT YOURE TALKING ABOUT!
basically dont spam this thread, or it kills the purpose
any crap will be deleted
remember you dont have to post something to watch it, theres a button down the bottom left saying 'watch this topic'
basically one thing i want to come from this thread, is how much work is actually involved in setting up a good 4AGTE
could those in the know please post up info such as:
Block - which series to choose, why, and any other info
Head - which series to choose, why, and any other info
exhaust manifold
intake manifold
injectors
ECU
fueling
pistons - which to use, why, and any other info, costs?
bearings
rods
crank
intercooler - what size, type and mounting orientation
turbo - which to use, why, and any other info, costs?
bov
wiring
wastegate
then of course theres a cert thats needed, and possiby brake upgrades
any helpful info re gearboxes, costs, time periods, clutches etc etc will also be helpful
discuss:
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby themaleman » Thu Nov 30, 2006 9:56 am
my 1's nearly done now, just wondering if the engine its self need 2 be certed? from wat ive herd it dosnt have 2 because it was orignaly superscarged (not an incresse of 20% power or watever it is). can any1 shead some more light on thius please?
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Santa'sBoostinSleigh » Thu Nov 30, 2006 10:06 am
by the looks of http://lvvta.org.nz/CertThresholdScheduleApril04V3.pdf (page 10, then yes you do)
Santa's Mega Sale
Postby Lloyd » Thu Nov 30, 2006 5:48 pm
If you fit or replace a wastegate with something else, or basically anything you should legally cert it
Postby l1ttle_d3vil » Thu Nov 30, 2006 6:32 pm
im particularly interested in the clutch/flywheel side of things, was going to start a new thread but may as well put it all in here!
i'm after a flywheel/clutch setup to go on an aw11 4agze block with w55 gearbox, hoping for around 140kw or more. main use would be road, but there will be the odd appearance at trackdays/skid comps etc so needs to handle that!
what are some decent brands of flywheel/clutch/pressure plates for the above use? trd, hks, exedy? anyone had any experience with these brands, is one alot better than the other? obviously the websites for these brands all say they are top quality, but which really is better??
would it be worth it to get an aftermarket lightened flywheel? what is the difference between aftermarket lightened flywheels and a factory 4agze flywheel which has been lightened (including price)? general opinion seems to be lightening standard flywheels isnt a good idea... :wink:
and am I going to gain much by running a 232mm flywheel instead of the 224mm 4agze flywheel?
cheers.
Postby vvega » Thu Nov 30, 2006 10:44 pm
Block - 7a cause cubes count
Head - blacktop ......bigger ex ports
exhaust manifold ummm a turbo one ??
intake manifold not the stock one they pop
injectors 500+ cc;'s
ECU should be at least teh equivalent to the money you have spent on the motor
fueling somthing that matches what your aiming to acheve hp wise and then some
pistons - forgies..ross make a good cheap piston..nice and light too
bearings trd ...what else
rods sanez or pauta
crank ummm.....the 7a one
intercooler - evo sized and V mounted
turbo - twinscrol with a matxhing manifold
bov one that works without leaking
wiring $&#$% knows why this is in here
wastegate one per scroll so you dont lesson the effect of a tuned pulse manifold
clutch ??
get a twinplate :D
once you get over 250kw your wasting your time with a single
vvega
Postby Crampy » Fri Dec 01, 2006 7:48 am
Take the stock 4AGZE engine, with the supercharger removed. Match it with an N/A inlet manifold, be it a big port or small port head. Could even chuck some Bluetop cams in, if you have some.
Put a action_dan or evil_si turbo manifold on it. Get an intercooler off tardme and plumb it all up, not too big though (depends on how much power you're looking for)
Start at a sensible boost level and go up from there, making sure of the tune.
That seems to be a good base starting point for a lot of turbo 4AGE project. Some stick to it, while others go bigger with more power, but that's when it costs more and more.
Crampy
Postby crnkin » Fri Dec 01, 2006 10:01 am
vvega wrote:turbo - twinscrol with a matxhing manifold
vvega, ive been wondering, is a twin scroll/entry better than a normal entry turbo of the same size? some say it is, some say it isnt, and if you could explain you can have my babies?
cher
deaf_homo "currrently yes"
crnkin
Postby myke » Fri Dec 01, 2006 2:31 pm
wats the most common turbo to use for this conversion on standard internals that have been refreshed?
i have been told an ht-18 from an rx7 s4/5, tdo4, tdo5,t3?
can someone shed some light on a turbo for street use?
Myke
myke
Postby IH8TEC » Fri Dec 01, 2006 2:49 pm
any of the above have proved good with results, i had a tiny t3 on my last setup, and it was awesome for the street. spooled really well and produced some good really good results.
