FWD to RWD
FWD to RWD
Postby NOLAW » Fri Dec 01, 2006 10:29 pm
im sure theres plenty of you here whos done it so who knows what needs to be changed on a FWD 4age (ze/te) to fit into a RWD, aka. ke20, starly,ke30 etc? like does the water pump, alternator etc need changing?
cher
NOLAW
Postby Zak » Sat Dec 02, 2006 9:20 am
viewtopic.php?t=46779
Thats most of it there.
Zak
Postby l1ttle_d3vil » Sat Dec 02, 2006 12:29 pm
yeah thats pretty much it all there. im doing it to a completely original fwd 4agze now, so ill be able to tell you everything soon. but pretty much all you really need to change for it to work is the inlet manifold and umm...the spigot bearing in the back for the gearbox. water pump and alt dont need changing or anything, you can just make up waterlines to adapt to your system. rwd mounts and waterlines just make it all easier and tidier but they're f**ken hard to find and expensive nowadays.
i think thats about it...but i am hungover so maybe not :x
Postby NOLAW » Sat Dec 02, 2006 7:35 pm
ok i red through the FAQ thing and i understad most of it, theres just one thing, i need one of those 3a backing plates, stupid Q and im not thinking very straight right now but what engine is a 3a :? :roll: and has anyone got a backing plate they want to flick off to me, its for a 4agze btw
NOLAW
Postby Zak » Sat Dec 02, 2006 7:48 pm
The 3a is the single over head cam 1500 engine from the ae85 and ae70
Zak
Postby NOLAW » Sat Dec 02, 2006 7:54 pm
cheers for that bro :D
NOLAW
Postby l1ttle_d3vil » Sat Dec 02, 2006 8:16 pm
even that isnt entirely necesary. its basically so you dont get dust and crap fly up into your flywheel/clutch etc which isnt a good thing i suppose. you can make up your own plate to cover the bottom part, and use a fwd backing plate for the top part though.
im just using a standard fwd one, nothing on the bottom half and ive never had any problems... :roll:
Postby KinLoud » Sat Dec 02, 2006 9:36 pm
The most important thing the backing plate does is correctly locate your starter motor.
I don't know BUT...
I would guess that you could use a backing plate off a fwd 3a, 4a, etc. I havent compared them but I guess that a fwd could do the job.
if the starter is on the correct side for your rwd gearbox. Lots of AE82 corollas will have the starter on the correct side.
Any comments on this theory?
Ken
Ham
021 408 863
