Where is my fuel pump gone?
Postby Fex_ » Sun Dec 03, 2006 5:38 pm
OK I have searched and looked at diagrams of my tank/fuel setup and nothing shows or tells me where the fuel pump is on my car, I just can't find it! Its not in the centre where the tank float thingy is and I can't see any other opening under the seat or underneath the car.
Its an AE92 1989 Levin. Please help, cheers. :)
Fex_
Postby thegreatestben » Sun Dec 03, 2006 5:40 pm
Uh aren't they internal as in, inside the tank?
thegreatestben
Postby Fex_ » Sun Dec 03, 2006 5:41 pm
Yes, but where in the tank, how do I get to it?
Fex_
Postby Rick » Sun Dec 03, 2006 5:43 pm
To get to your fuel pump you need to remove the petrol tank from the car. When removed you will see where the fuel lines enter the tank. Remove the lid with the fuel lines on it, and that is where your fuel pump lives... :P
Postby Fex_ » Sun Dec 03, 2006 5:51 pm
Ohhh thank you, thank you... Will do that, just need to jack the car up high enough some how. :)
Fex_
Postby postfach » Sun Dec 03, 2006 6:38 pm
PLEASE be careful and remember to disconnect the wires to the float and pump (both connectors are probably next to each other) before you drop the tank! also might be wise to disconnect the fuel lines, otherwise you might accidentally rip something off
postfach
Postby KinLoud » Sun Dec 03, 2006 6:56 pm
A lot of Toyota fwd cars have access to the fuel pump by removing the rear seat cushion and undoing an access panel.
Check under your backseat before you remove the fuel tank.
What are you trying to do?
Ken
Ham
021 408 863
Postby CAMB01 » Sun Dec 03, 2006 7:23 pm
No AE92's you have to remove the fuel tank.
I had to when i replaced my 4age pump with a 4agze pump.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby bluemaumau » Sun Dec 03, 2006 7:31 pm
yup ae92s you need to drop the tank, ae101s being a much better car are accesible under the rear seat, 8)
Postby Santa'sBoostinSleigh » Mon Dec 04, 2006 8:40 am
my ae111 bzg levin, i removed the rear seats and pulled it out the top of the fuel tank
my ae92 fxgt rolla looks like you can do the exact same thing
come to think of it so does my st215w GT-T Dina
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby CAMB01 » Mon Dec 04, 2006 9:01 am
The only thing you can pull out of the tank under the rear seat on an AE92 is the fuel level float.
The pump sits further back in the tank.
Trust me been there done that :)
CAMB01
Postby bluemaumau » Mon Dec 04, 2006 4:43 pm
CAMB01 wrote:Trust me been there done that :)
seconded
Postby soopachargen » Mon Dec 04, 2006 7:14 pm
just for future reference to do an ae82 pump you have to remove the tank too
When in doubt, down and out.
soopachargen
