No pull anymore
No pull anymore
Postby FrEsH » Thu Dec 07, 2006 12:28 am
Hey guys, i've got a starlet GT which i've been slowly modding up..anyway it has some issues that i can't resolve..
a) it has a high idle, the idle adjustment screw is all the way in and it idles at (cold) 2500rpm and (hot) 1200rpm...this only starting happenign after i got my alternator replaced..
b) it seems to have lost a lot of its pull in the past 6 months or so which is odd because i have put a highflow turbo and external wastegate on it (car lost pull before these mods)..mym ate took me for a ride in his stockish GT and his had a lot more push you into the seatness...
c) it runs pretty rich and burbles and backfires when ur off the gas...backfires when u go back on it too...car doesnt blow any smoke though and runs very smooth...
any ideas/help would be greatly appreciated..i'ved tried checking for ecu error codes and all it does is flash the engine light continuously...
FrEsH
Postby IH8TEC » Thu Dec 07, 2006 12:54 am
sounds like it's running massively rich, too rich will also lose power, but you dont mention if you have any fueling mods?
you've probably heard before, but have you checked with air/fuel meter?
running slightly rich on idle can also increase the revs (to a point before it tries to stall the engine) and i'm assuming you've checked for vacuum leaks.
sorry can't be too much help, but a few ideas there, and you may have heard them before
:lol:
Postby FrEsH » Thu Dec 07, 2006 12:57 am
i think its running rich too but not sure..but i have done no fuelling mods, it has not been checked with an air/fuel meter i've checekd it for vacuum leaks but could not find any ive also tested het throttle position sensor and that was fine...
FrEsH
Postby MrOizo » Thu Dec 07, 2006 9:19 am
if the engine light is flashing all the time, have you checked the codes?
have a check with the timing also - might be a cause for the lack of power.
MrOizo
Toyspeed Legend
Postby 79rolla » Thu Dec 07, 2006 9:27 am
it has an automatic choke doesint it? maby its stuck on or sumthing
past: AE82 FXGT
79rolla
Postby FrEsH » Thu Dec 07, 2006 10:32 am
MrOizo if the engine light flashes constantly does that mean somethings wrong?
Also how would i check teh automatic choke? Could this account for some of the power loss also?
FrEsH
Postby MrOizo » Thu Dec 07, 2006 10:50 am
yah... well firstly - does it flash as soon as you turn it on?
or only once you have been driving for a little while?
if its flashing then the diagnostics pins might be bridged.
have a look at the patterns of the flashing.
if its something like [flash] [flash] [flash] pause [flash] [flash] [flash] [flash] long pause....
if its constant flashing without any pauses its indicating that nothing is wrong and that the T & E1 are bridged in the diagnostics plug.
have a look here for a better definition on all this and the meanings of each code:
http://www.club4ag.com/faq%20and%20tech ... 0Codes.htm
MrOizo
Toyspeed Legend
Postby trdfxgt » Thu Dec 07, 2006 11:11 am
i had a mazda 1600 turbo do exactly that it was the crank pully key way due to the movement the timing went out then loss of power rich running and back fires
trdfxgt
Postby FrEsH » Thu Dec 07, 2006 11:17 am
hmmm so looksl ike i should get the timing checked then defiantely...
Yes MR Oizo to check teh codes i bridged the pins and its falshing continuously so that means theres no errors i guess...thanks a lot for your help
How would i check my timing? or is it easier jsut to take it somewhere
FrEsH
Postby trdfxgt » Thu Dec 07, 2006 11:54 am
id take it somewhere up to you though it wont be dear to check
trdfxgt
Postby Dell'Orto » Thu Dec 07, 2006 11:56 am
As for not pulling anymore...you sure you're not just used to the car? And being a passenger, a car always feels faster.
Postby FrEsH » Thu Dec 07, 2006 1:41 pm
na my mates agree and they're always passengers..defaintely lost its bite...
Ahhh anotehr thing to do with hte high idleing problem, itsl ike an automatic...as in i put it in first gear and ease teh clutch out giving it no gas at all and it will accelerate up to around 2500rpm...with no gas..just by itself..
FrEsH
Postby Caveman » Thu Dec 07, 2006 7:48 pm
ill check your timing when you bring your car over to do ic pipe 8)
AW11 Track Toy
Formerly known as 1998
Caveman
Postby SUBARUCONVERT » Thu Dec 07, 2006 10:30 pm
sounds like u have some kinda vac leak, how much vac is it running at idle?. is the water temp normal? around halfway? check the timing, plugs and lead condition
3ST150
SUBARUCONVERT
Postby FrEsH » Fri Dec 08, 2006 12:01 am
oh cheers dylan that would be wicked mate :)
FrEsH
Postby FrEsH » Fri Dec 08, 2006 1:27 am
water temp is normal..its running jsut above 20psi vac on idle
FrEsH
