HELP!!!!!! engine wont start
Postby andyae85 » Sun Dec 10, 2006 3:33 pm
so i just degreased and waterbalsted ( probably not the best idea :? but it looks immacualate) but anyway went to start again and it wouldnt cos there was water in the sparkplugs, so i blew the water out then went to try again and it turned over but wouldnt start and made a sort of whistling squeeling noise and some smoke or steam came out of th podfilter :? any help would be greatly appreciated
andyae85
Postby 79rolla » Sun Dec 10, 2006 3:56 pm
did you get sum water in your pod filter/engin?
past: AE82 FXGT
79rolla
Postby andyae85 » Sun Dec 10, 2006 3:57 pm
ummmm mustve done :? man im hell stressing out ay
andyae85
Postby 79rolla » Sun Dec 10, 2006 4:00 pm
umm all i know is water is RELLY bad for engins
somone els that knows more can fil in the deatales
past: AE82 FXGT
79rolla
Postby andyae85 » Sun Dec 10, 2006 4:04 pm
yea please someone???????????? i think ive done something bad ay :cry:
andyae85
Postby CAMB01 » Sun Dec 10, 2006 4:09 pm
Dry out all your electrical plugs in the engine bay.
Remove the air filter and look inside the intake to see if theres any water in there.
Remove the distributor cap and dry the dizzy out.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby andyae85 » Sun Dec 10, 2006 4:22 pm
yea just dried everything out again and tried to start, ran for about 10 sec real rough then died, i tried again and all the smoke and squeeling noise came from round the filter again so i took it off tried again and like smoke or steam came out of the throttle body and it wouldnt start again :cry:
andyae85
Postby CAMB01 » Sun Dec 10, 2006 4:27 pm
all the squealing noises would be water on the fan belt/s.
Try spraying CRC on the belt/s.
remove the spark plugs and crank the motor over and see if anything comes out.
Keep drying things out.
Sounds like you might have the leads round the wrong way.
CAMB01
Postby andyae85 » Sun Dec 10, 2006 4:43 pm
k well i just removed the spark plugs and blew evrything out and its idleing, a bit rough atm but ill leave it for a bit to warm up
andyae85
Postby andyae85 » Sun Dec 10, 2006 4:49 pm
its still ideling real rough and whenl i go to give it some gas, it coughs and burps and lags real bad :?
andyae85
Postby 79rolla » Sun Dec 10, 2006 4:55 pm
it it carbed or injectd? terboed?
past: AE82 FXGT
79rolla
Postby Adydas » Sun Dec 10, 2006 5:03 pm
Terboed???
Adydas
Postby andyae85 » Sun Dec 10, 2006 5:05 pm
its injected, had it ideling for about 20mins so i thought id take it or a little drive and i backed about 5 meters, was running rough as and then it just died and now it wont start :cry: i hope i havent done anything too bad :cry:
andyae85
Postby flat_0ut » Sun Dec 10, 2006 5:08 pm
Get out the hairdryer :wink: . Im sure it'll come right
flat_0ut
Postby 79rolla » Sun Dec 10, 2006 5:08 pm
turbo'd*
(sorry i suck at spelling)
past: AE82 FXGT
79rolla
Postby andyae85 » Sun Dec 10, 2006 5:10 pm
yea it better, i aint got no more money to spend fixing it :cry:
andyae85
Postby Adydas » Sun Dec 10, 2006 5:17 pm
Its possibly more wise at this stage to leave it at let it dry before it does do more serious damage, Dont stress to much as hard as it is now.
I remember i dropped somthing in water once ( i think it was a phone ) and i was freaking out ( was younger and it was alot of money then ) and i put it in the hot water cupboard for the night as i was told and tryed not to freak out.
Sure enuf the next morning it worked mint, just needed to dry out.
Adydas
Postby andyae85 » Sun Dec 10, 2006 5:19 pm
so just leave it for a while ya reckon?
andyae85
Postby Adydas » Sun Dec 10, 2006 5:25 pm
I certainly think it would be wise..
Adydas
Postby andyae85 » Sun Dec 10, 2006 5:26 pm
ok, man i hope its alryt :?
andyae85
