replacing inner cv joint
Postby deaf_rattle » Tue Dec 12, 2006 7:04 pm
wrked out what my problem is, inner cv joint is knackered.
how does one go about replacing one of those?
ae92 fxgt manual if that makes any difference
Postby Zak » Tue Dec 12, 2006 7:29 pm
Easy as, it all just slides together, but you do have to remove the half shaft to get at it. It's pretty uncommon for them to fail though.
Zak
Postby bluemaumau » Tue Dec 12, 2006 8:40 pm
yea apparently very uncommon just take your shaft out clear the crease and depending on the type of cv you may need circlip pliers.
Postby deaf_rattle » Tue Dec 12, 2006 8:42 pm
the clip holding the boot had come off, boot had slid off and grease everywhere.
inner cv knackered
cheers, will replace this weekend. fun fun
Postby repowered » Tue Dec 12, 2006 10:24 pm
deaf_rattle wrote:the clip holding the boot had come off, boot had slid off and grease everywhere.
inner cv knackered
yep thats what happened to mine or they split and make a hurr of mess
i did my ae82 ones, just trying to remeber how I did it lol, it was pretty easy you just remove the hub nut, loosen the 3 top strut bolts and then remove the caliper and the bolt at the bottom of the strut (on the suspension arm), and then push the suspension arm down with your foot and that taperd shaft might pop out with and luck or you might have to lever it. tap the side of it with hammer first that help I found.
Pull the strut away from the car from you abit the half shaft should pop out the gearbox, and then CV come's out of the hub, will have the driveshaft attached, put driveshaft in vice and then bash the cv off with abit of wood and a hammer.
im sure ive missed stuff and that was on a ae82 that didnt have a 4age.
***waits for torrent of corrections*** :roll:
Rollin!
repowered
Users browsing this forum: Google [Bot] and 32 guests
