Aftermarket Steering wheel
Postby Shads » Wed Dec 13, 2006 7:07 pm
Hey there,
Currently in the process of looking for a decent aftermarket wheel for my ae101 (kinda sick of the one that it has in at the moment)
I have been offered a evo 3 momo steering wheel
1. With the correct boss kit will it fit?
2. How hard is it to remove the current one / install the new one with the boss kit.
Save it for the Strip
Shads
Postby Ae92typeX » Wed Dec 13, 2006 9:01 pm
Assuming the momo wheel takes a standard momo boss kit(which it should) and also assuming you dont have an airbag, its a piss easy thing to do.
Ae92typeX
Postby RED TOP MR 2 » Wed Dec 13, 2006 10:37 pm
i have a feeling that that wheel was a factory option.therfore wheel and boss kit are combined.you cannot change that and the spline will only fit mitzys.momo made a few factory options for some makes e.g subaru.yould be looking for an aftermarket momo and toyota boss kit.
RED TOP MR 2
Postby Ae92typeX » Wed Dec 13, 2006 10:43 pm
RED TOP MR 2 wrote:i have a feeling that that wheel was a factory option.therfore wheel and boss kit are combined.you cannot change that and the spline will only fit mitzys.momo made a few factory options for some makes e.g subaru.yould be looking for an aftermarket momo and toyota boss kit.
ive seen both senarios. many factory momos still use normal boss kits and can be adapted.
Shads, are you able to take a closer look at the wheel? it will then be obvious which of the two options above it is.
Ae92typeX
Postby Jazza » Thu Dec 14, 2006 7:56 am
My civic i could do a straight switch to the momo, but when it came to the Legnum it was no can do :cry:
1996 Curren - On Tardme
Jazza
Custom Steering Wheel
Postby shiz » Wed Jan 24, 2007 11:09 pm
I think you need a Boss Kit for Toyota only, but most momo fit all Boss Kits. I changed mine, easier as, took just under 5 mins.
shiz
Postby Bumpy » Sat Jan 27, 2007 5:59 pm
When you undo the nut to take the steering wheel off, leave it on the thread, and pull the wheel REALLY HARD.
If you take that nut off all the way you can strip the thread when the wheel comes off and **** it all up ...
Bumpy
Postby postfach » Sat Jan 27, 2007 6:25 pm
Bumpy wrote:When you undo the nut to take the steering wheel off, leave it on the thread, and pull the wheel REALLY HARD.
not to mention hitting yourself in the face! a little wd40/crc will help as well, spray some on the spline before you put the new one on too, chances are you will want to take it off again to get it straight.
postfach
Postby Shads » Mon May 14, 2007 5:50 pm
Raising a post from the dead but..
Where are the screws located to remove the factory steering wheel?
Cheers.
Shads
Postby MR2SIK » Mon May 14, 2007 6:42 pm
underneath the horn?
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Alex B » Mon May 14, 2007 8:10 pm
Yeah usually you pull the horn button off, sometimes they have screws under the wheel.
Users browsing this forum: Google [Bot] and 3 guests
