C52 Gearbox...spline will turn but not the stubs?
Postby no_8wire » Wed Dec 20, 2006 10:54 pm
Ok, so I took apart the gearbox so I could change the bell housing from a one hump to twin hump...
now the first time I put it back together I messed up the direction of the reverse shaft and so couldnt get the lockbolt in, so I stripped it down again, fixed that and now I have this problem.
When ever I try to turn the axles stubs, I cant. However you can still turn the spline that comes out to meet the clutch.
Any ideas on what to look for when I take it apart again?
no_8wire
Postby no_8wire » Thu Dec 21, 2006 1:24 pm
I guess not many people take apart there GBs then aye?
no_8wire
Postby sergei » Thu Dec 21, 2006 1:44 pm
reverse all the time engaged?
Postby big_boy » Thu Dec 21, 2006 4:11 pm
can you still turn the input sharft if its in gear ( prefably 4th or what ever one is 1-1) if so do the out puts turn then ??????
big_boy
Postby no_8wire » Thu Dec 21, 2006 9:39 pm
Yes when I change the gear, in some of them it will turn, but is difficult. How ever the stubs still dont move
Well I suppose I will find out when its apart tomorrow anyway...
Is a LSD box by the way, I dont know if that makes any difference
no_8wire
Postby big_boy » Fri Dec 22, 2006 10:13 am
if its LSD dousent it need oil to work ??????
big_boy
Postby bluemaumau » Fri Dec 22, 2006 12:29 pm
yup
Postby no_8wire » Fri Dec 22, 2006 1:37 pm
So you think put some oil in and try?... I mean you cant turn it at ALL
no_8wire
Postby QikStarlie » Fri Dec 22, 2006 1:58 pm
look around your floor for 2 small ball bearings. they go in the selector shafts. without them the box will lock up.
QikStarlie
Postby no_8wire » Fri Dec 22, 2006 2:36 pm
Ok will do
no_8wire
Postby Santa'sBoostinSleigh » Fri Dec 22, 2006 3:01 pm
big_boy wrote:if its LSD dousent it need oil to work ??????
C52 wont be LSD unless its aftermarket
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby no_8wire » Fri Dec 22, 2006 3:54 pm
TRD plate LSD all the way...dealer option for AW11s
8)
no_8wire
Postby Santa'sBoostinSleigh » Fri Dec 22, 2006 4:09 pm
peow peow ;)
Santa's Mega Sale
Postby no_8wire » Fri Dec 22, 2006 4:14 pm
Anyway i stripped it down...turn when the box isnt torqued right down...so maybe I need to get some thinner bearings?
mmm
no_8wire
Postby Mr Revhead » Fri Dec 22, 2006 4:20 pm
thinner bearings?? wtf.
id be checking your assembly
Postby no_8wire » Fri Dec 22, 2006 4:22 pm
Thinner races then...Will go back, but as soon as the bolts were loosened it would turn...so yeah?
no_8wire
Postby Mr Revhead » Fri Dec 22, 2006 6:12 pm
recheck things......
you dont get different sized bearings. you can get some different size washers etc. but id say youv put it together wrong
Postby vvega » Fri Dec 22, 2006 9:07 pm
you do get different sized bearings
dependant on box modle
you also have thrust washers to setup the preload
perhaps a transmission specailist is your best bet :D
v
vvega
Postby Mr Revhead » Fri Dec 22, 2006 9:12 pm
no toyota box i have seen has different size bearings available. and definitly not the c series.
i guess you could have gotten aftermarket ones that are incorrect size.
Postby vvega » Fri Dec 22, 2006 9:23 pm
Mr Revhead wrote:no toyota box i have seen has different size bearings available. and definitly not the c series.
c56 and c52 have diffent size bearings on the diff........had to swap tham a few times
ive been thoiugh this with toyota before..sometimes the epc lies :)
vvega
Users browsing this forum: Bing [Bot], Google [Bot] and 23 guests
