front wheel bearing ST190 corona.
Postby rxtoy » Thu Dec 21, 2006 5:36 pm
was changing my pads due to squealing sounds and brakes getting hot, wheel is pretty wobbly up and down. i bought a new wheel bearing and tried getting hold of a manual but neither the local repco or supercheap had one available.
i've done wheel bearings before but this one looks pretty different and because i've got no spare car i just want to make sure i've got everything there for the change before i get into it.
any tips and tricks and will i need a press to get the old one out/new one in.
also if anybody has a manual and can email me a copy of the relevant pages that would be awesome (or even the celica ones from the same year, i'm pretty sure they are the same.
str_ng_r@hotmail.com
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Mr Revhead » Fri Dec 22, 2006 8:57 am
thay have a standard toyota bearing arrangement....
what cars have you done bearings on?
Postby rxtoy » Fri Dec 22, 2006 9:42 am
RA28 celica (with corona front struts),
mitsubishi 1981 EX lancer,
nothing new or FWD so far
been talking to a mate and it sounds like i need to press the bearing out and since i'm not going to have access to a press before xmas and i need the car i'm going to get a hub from pick a part and swap that in. will mean i can use the car and swap the new bearing into my original hub once i get a chance too.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Mr Revhead » Fri Dec 22, 2006 9:50 am
yeah itll be different from those.
yes you need a press
Postby rxtoy » Fri Dec 22, 2006 4:41 pm
swapped in one from pick a part, had to buy the CV joint with it because couldn't undo it (other side just kept turning).
now i've got more problems, when i took the old hub out the shock dropped out, turns out the bearing at the top of that has collapsed as well.
looks like i might be staying in Auckland for Xmas :(
anyone got a strut top they want to sell?????
cheers,
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby AceSniper » Fri Dec 22, 2006 6:12 pm
if you got a new bearing an brought the hub into a shop it costs all of $20 for them to press a new one in, but sometimes the center flange is stuffed from the run bearing
AceSniper
Postby rxtoy » Fri Dec 22, 2006 6:42 pm
i'm not worried about the cost, or even about doing it. i just needed the car ready for driving on xmas day and i'm working saturday and sunday so no chance to do it then. i can get it pressed out at work next year, just the workshops are closed up at the moment.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby Rob » Sun Dec 24, 2006 10:53 am
Hey man did you get those struts? I got a couple of st170 struts you can have
011772885
09 4823296
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby rxtoy » Mon Dec 25, 2006 6:57 pm
that you brumby????
need ST190 one's, i'm off to pick a part tomorrow to get one anyway, its already a lot better with the new hub in so hopefully this will sort it completely
hmmm, wonder if ST170's would go in the celica, they're RWD right???
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby sergei » Tue Dec 26, 2006 6:13 am
"T" series toyota (as in ST170) are either FWD or 4WD....
Users browsing this forum: Bing [Bot] and 7 guests
