more st162 questions - EGR
Postby tractionfree » Sun Dec 24, 2006 4:13 pm
the b*stard celica saga continues. after getting the head off to replace the gasket that was already blown in the engine i replaced the old engine with, with the blown big end bearings... phew
ive started blocking off the EGR gear. when i took the head off (with the inlet manifold still on), i had a little black valve drop out of it, im guessing its EGR related. obviously im not planning to use any of that gear anyway.
so do i unbolt the whole shebang off the side of the block? or better to leave it on, but with the lines plugged? and should i leave the valve in, remove it or fit a blanking off plate? id really appreciate some advice, cheers
tractionfree
Postby tractionfree » Tue Dec 26, 2006 8:25 pm
come on... .someone somwhere must have disabled their EGR?
tractionfree
Postby Rob » Wed Dec 27, 2006 7:49 pm
I do it to alot of diesels.
All you need to do is jam a frost plug in the hole and will be sweet, or if you want to get rid of the weight then blank it like you say and rip it all off
1990 ST185H - project
1996 VS Acclaim wagon
Rob
