Does anyone know about 3.8 V6 Holden commodores?
Postby ollieboy » Sun Dec 24, 2006 5:17 pm
My friend has one and her check engine light came on but its on even when engine is off and the light doesn't turn off at all. Is this a known problem or will I have to check for error codes, is it even possible to check for error codes on Holdens without special equipment?
Also, where the accelerator cable connects theres another cable coming off that that is broken, it heads down behind gearbox, any ideas?
Sorry its not a Toyota but Toyota people know more shiz than any other people.
ollieboy
Postby QikStarlie » Sun Dec 24, 2006 5:40 pm
that other cable is for the auto kick down from memory. could be wrong tho
QikStarlie
Postby ollieboy » Sun Dec 24, 2006 5:45 pm
That makes sense, I think you are right, that explains a few other things with the car.
ollieboy
Postby B ROWDY » Wed Dec 27, 2006 1:00 pm
Should have bought a Ford
B~ROWDY The Thread Whore Formerly Known As SERABABY
B ROWDY
Postby Lith » Wed Dec 27, 2006 3:11 pm
B ROWDY wrote:Should have bought a Ford
Yep. Then you'd know what the problem is - conveniently circled from the factory.
Lith
Postby Bling » Wed Dec 27, 2006 4:01 pm
thats a new one..... :roll: :wink:
go FORD
wait whats the thread about again...... ah... just pull the bulb Ollie ;)
Postby ollieboy » Wed Dec 27, 2006 5:21 pm
it turned out to be a loose fuel cap :roll: put a new one on and its fine.
ollieboy
