wof and rust?
wof and rust?
Postby rwd_mayhem » Wed Dec 27, 2006 2:21 pm
does rust in a door make you fail a wof? as its not structural. like a rugby ball sized hole of rust? lol
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Re: wof and rust?
Postby Rick » Wed Dec 27, 2006 2:54 pm
rwd_mayhem wrote:does rust in a door make you fail a wof? as its not structural. like a rugby ball sized hole of rust? lol
It depends where the rust is on the door. If rust is around the hinge area and/or where the door latches are it will fail.
Sound like your on the market for a new door 8O
Postby l1ttle_d3vil » Wed Dec 27, 2006 3:20 pm
BUT ... iirc you don't need doors for a WOF, so you could always take them off, get your wof then put your doors back on :lol:
and yes, I have heard of this being done before and passing...
Postby Bling » Wed Dec 27, 2006 3:58 pm
you're shitting me??? 8O
that would be classic to see!
Depends on WOF inspector I guess, I tried for WOF without backseat and belts..... and failed :evil:
Thats a fair amount of rust tho, should have rivited a plate in and bogged it before going for WOF :lol:
Postby l1ttle_d3vil » Wed Dec 27, 2006 4:21 pm
BZG|Bling wrote:you're shitting me??? 8O that would be classic to see!
yep, true story. it was on some old sh!tbox truck which had a bit of rust in the doors, so the dude took his doors off hence removing the rust :lol: then proceeded to get his wof. rules may have changed since this happened though...
Postby Dell'Orto » Wed Dec 27, 2006 6:14 pm
Provided its not in the frame it ought to be fine. One of my doors is getting quite rotten but its only the skin. WOF people have never made mention of it.
Postby Lloyd » Wed Dec 27, 2006 6:21 pm
Should be on the VTNZ website under the VIRM stuff. Rust within 150mm of a hinge is a fail
Postby Rob » Wed Dec 27, 2006 7:46 pm
Within 150mm of a hinge or catch. or an inch in diameter
1990 ST185H - project
1996 VS Acclaim wagon
Rob
