Engine vibration, help please
Postby eskimo » Fri Dec 29, 2006 2:18 pm
Hey, I am new to the forum and soon to the club just gota find out where to join and who to pay.
Any way I have just bought I 1996 st206 Toyota curren trd sports with the 3sge twin cam. and love it to bits
I have only done 500kms in it since I have bought it and there is a vibration, like lose exhaust heat shield, coming from the motor at about 3000rpm.
The only issue is that the shield isn't lose at all and it only does it under load and only for a couple of seconds. I had a similar sound in my old st185 gt4 and the mechanic said it was the idler bearing. the cambelt in my curren was replaced 56,000kms ago so I assume they replaced the bearing at the same time.
Would any one know what also could be causing this vibration I don't know to much about the 3rd gen 3's
any assistance would be appreciated
eskimo
Postby big_boy » Sat Dec 30, 2006 9:02 pm
no one can tell with out seeing the car but start with
-water pump
-alnator
-all drive belts includeing pullys
-timeing idler ( dont assume its done most people dont assumption is the mother of all $&#$% ups trust me )
try them first
big_boy
Postby eskimo » Sat Dec 30, 2006 11:20 pm
cheers,
i think i must just get the cambelt replaced as all i have to go on is old owners word and the sticker on the cam cover. that way i can check the water pump and the idler at the same time.
eskimo
Postby soven » Sun Dec 31, 2006 11:10 am
will be interested in the outcome as I hear a rattling sound from my 3sfe engine when I hit the gas.(just for a second) , never bothered to check what rpm but I will say that it is close to 3500. Cambelt changed but waterpump etc have not been changed. Let me know how you go. The thing is, if I rev while stationary, the rattle does not come on.
soven
Postby sergei » Sun Dec 31, 2006 11:14 am
It could be cooked catalithyc convertor, that is shrunk and vibrating inside it's casing..
Postby eskimo » Sun Dec 31, 2006 3:35 pm
yea i will, cant do any thing as my machinic is away untill the 15th of january, I was also thinking it could also be the drive line. i had the car checked by vtnz and my mechanic and nothin came up. so im confused as to what it wold be. ill post the out come when my machic is back and had a look at the car.
eskimo
Postby Boosted_162 » Sun Dec 31, 2006 9:58 pm
I agree with Sergei, at least with it being part of the exhaust system. I got the same (annoying) noise. Happens when revving while stationary, so isnt driveline.
Has a cat back exhaust so isnt the 2nd half. My front half of exhaust is mashed due to the ride height so could also possibly be that? I might check it out tomorrow, and replace it with my other front pipe.
EDIT: Could be the top heat shield, my first GT4 didnt have that noise, and it didnt have the shield tho this one does. Not sure what sorta shields the 3rd gen 3SGE has tho
Postby Toymota » Mon Jan 15, 2007 11:41 am
My ST185 has this same rattle to, it does it both under load and when free revving.
I've seen ST185 with the heat shield removed and I always wondered why they would do that, could this be the reason?
Although, my heat shield doesn't seem loose so I can see how it could rattle like that.
If anyone solves it, let us know.
Toymota
Postby big_boy » Mon Jan 15, 2007 12:43 pm
get it hot & try rechecking the bolts on the heat sheild my 2E-E corolla one was tight when cold but rattled when hot & its a painful problam to fix trust me they burn
big_boy
