ke70wagon20v wrote: im currently doing this to a friends ke70 race car with a black top which should get a trashing so will be interesting to see how it holds up in terms of not cooling the head correctly
johntramp wrote:I already have a hole in the firewall too![]()
is the only reason for changing the thermostat housing for firewall clearance?
can you please explain the difference between fwd and rwd water pumps etc.?
