18r miss firing
18r miss firing
Postby Pies » Wed Jan 03, 2007 9:24 pm
toyota 18r is randomly miss firing when driving down the road (note: not missing when car is turned off)
no apparent pattern. just, misses. under power, cruising, up hill, down hill,
gave the diz rotor a light sand. no help. checked cap, bit white on the contact points. brand new leads. plugs = all good. sprayed remains of can of carb cleaner down the carb throat.
anything else i could try?
Current Rides:
Pies
Postby Rob_GTZ » Wed Jan 03, 2007 9:48 pm
Check that the Intake manifold is bolted up tight?
Rob_GTZ
Postby bro_nation » Sun Mar 04, 2007 10:24 am
i got the exact problem with my 18r engine in my ute does big as backfires( very shameful) but i had a ramflow ontop of my carby and it back fired and burnt a massive hole in the filter if u have found your problem can you please let me know whats causing it?
bro_nation
Postby big_boy » Mon Mar 05, 2007 8:51 am
im gessing condencer is on its way out
any signs of tracking arround the coil or cap??
is the coil clean
is the coil over heating??
for sale EE90
big_boy
