toyota 18r is randomly miss firing when driving down the road (note: not missing when car is turned off)
no apparent pattern. just, misses. under power, cruising, up hill, down hill,
gave the diz rotor a light sand. no help. checked cap, bit white on the contact points. brand new leads. plugs = all good. sprayed remains of can of carb cleaner down the carb throat.
anything else i could try?
