Oil level light
Oil level light
Postby tianporn » Thu Jan 04, 2007 8:13 pm
Hey,
Mum has a 96 Toyota Estima - same as Previa. The oil level light comes on and stays on for a little while and dissapears. Happens everytime it's driven. The thing is I checked the oil a few time and its pretty much topped up. Tried resetting the ECU as well. Is it a faulty sensor or wtf?
Thanks!
tianporn
Postby Alex B » Thu Jan 04, 2007 8:16 pm
Try a new sensor. Not expensive. Id assume its not very nice to get at on one of those though.
Postby Crampy » Thu Jan 04, 2007 8:29 pm
Do you mean the oil pressure light on the dash?
Does it do it while you're driving, or just stays on for a bit when you first start it?
It does take a little time for pressure to build up.
Crampy
Postby 85AW20v » Thu Jan 04, 2007 9:02 pm
Could also just be showing you that the light itself is working and the bulb hasn't blown.
See ya
Simon
85 MR2 20v
85AW20v
Postby Jason T » Thu Jan 04, 2007 9:15 pm
Faulty float sensor in the sump that aint cheap to buy new
Remove bulb use dip stick
Fixing Toyota's since '87
Jason T
Postby tianporn » Thu Jan 04, 2007 10:56 pm
Yup its the light that reads 'oil level'. Happens when im driving. Jason T sounds about right... May just do that or ignore it.
However, does it make the ECU run the car run in limp mode? Sorry not too familiar with Toyota's anymore haha 8)
tianporn
Postby Crampy » Thu Jan 04, 2007 11:16 pm
Oil level, what will they think of next 8O
Surely if you check the level with the dip stick regularly, you wouldn't need a more expensive float and sensor setup.
Geez, they sure do try to cover all the bases with cars now don't they.
My first car, the fuel light didn't even work! I found out the hard way :oops:
Crampy
Postby JRS » Fri Jan 05, 2007 2:49 am
you ARE checking the oil level with the dipstic under the passengers seat and not looking at the oil level in the reservoir under the bonnet right?
meh.....
JRS
Postby tianporn » Thu Jan 11, 2007 1:13 am
JRS wrote:you ARE checking the oil level with the dipstic under the passengers seat and not looking at the oil level in the reservoir under the bonnet right?
Yes under passenger seat. Im not that dumb :lol:
tianporn
Users browsing this forum: Google [Bot] and 3 guests
