Adydas wrote:forged pistons approx 1k
eagle rods approx 700
new bearings 100-200
Where are you making these figures up from?
i could find a recipt for the $1200 i paid for JE pistons, eagle rods And bearings.
Who are u using to put ur bottom ends togeather? because ur getting well ripped off. If u supply a stock short block, then supply pistons, rings, rods, bearings, o rings, gaskets. I cant see 2k in stripping the block, cleaning, small amount of boring and honing, surface the deck then assemble.Mmm, Boost wrote:You've left out assembly costs...labour would still be close to if not more than $2k.
SUBARUCONVERT wrote:Who are u using to put ur bottom ends togeather? because ur getting well ripped off. If u supply a stock short block, then supply pistons, rings, rods, bearings, o rings, gaskets. I cant see 2k in stripping the block, cleaning, small amount of boring and honing, surface the deck then assemble.Mmm, Boost wrote:You've left out assembly costs...labour would still be close to if not more than $2k.
And Adydas i was using avgerage cost from places in NZ.
Mmm, Boost wrote:SUBARUCONVERT wrote:Who are u using to put ur bottom ends togeather? because ur getting well ripped off. If u supply a stock short block, then supply pistons, rings, rods, bearings, o rings, gaskets. I cant see 2k in stripping the block, cleaning, small amount of boring and honing, surface the deck then assemble.Mmm, Boost wrote:You've left out assembly costs...labour would still be close to if not more than $2k.
Perhaps you should ring around a few places. I'm not saying you cant get it done for less, or that $2k is an average price, but skilled labour isnt cheap.
