2LTR Rona wrote:the T50's have to be the easiest box ever to work on.
Take off the shifter / rear tail housing section, remove the small plate on the top holding 3 springs & ball bearings in, lay it on its side, remove about 8 bolts & lift one half of the casing off (might need a little tap with a soft faced hammer if sealant has been used)
It has 3 shafts, input shaft, lay shaft & main shaft. once open its becomes pretty easy as to whats what, bearings are pressed on & there are a couple of cir clips holding things together as well.
if you start pulling it apart lay everything down on a bench in the order you took it off, otherwise you end up with this....
Volodkovich wrote:I have to replace a couple bearings in my t50 too, any one know the rough prices on them(specifically the input shaft bearing) ? Is it best to go toyota oem bearings or just get ones from a bearing shop (i.e. are they a standard size?)
l1ttle_d3vil wrote:ive done it before without a manual, just make sure you pull everything to bits real slowly and check which way it goes back in.
there are HEAPS of little bits, clips, bearings etc etc which fall out when you pull it to bits, so make sure you know how they go back together. good idea to take pictures too.
otherwise if you get really stuck ive got a t50 here i can pull apart, if you need to confirm how something goes back in.
like 2LTR RONA said, they are simple boxes to work on - just make sure you have everything in order. if you do that you can't go wrong really.
