Help Needed Urgently
Postby SpeedRacer » Mon Jan 08, 2007 9:03 pm
Ok im freakn out, my biggest fear has come true - i think ill miss dyno tuning - AGAIN!!!!
basically - took dash cluster out to hook up tacho (still not hooked up) and now car wont start.
it has spark, it has fuel, link has power, replaced all the fuses, checked the grounds.
im lost :( and really dont wanna miss my session tomorrow :cry:
any help muchly much appreciated
-Speed
Sinister Sleeper 35
SpeedRacer
Postby SpeedRacer » Mon Jan 08, 2007 10:06 pm
ok... change in diagnosis
i remember the last hing i changed was a seal on an injector so i undid the fpr and no fuel leaked out like it should. turned the key to on so the fuel pump will prime the injectors and no fuel spills out either.
can hear the fuel pump priming but no fuel...
any ideas?
-Speed
Sinister Sleeper 35
SpeedRacer
Postby Lloyd » Mon Jan 08, 2007 10:17 pm
Is there actually fuel getting to the rail?
Just because you can hear the pump doesn't mean its making enough pressure. Get a pressure/flow gauge on there and see whats happening
Postby SpeedRacer » Mon Jan 08, 2007 10:23 pm
undid the hose and no fuel flows out.
please dont tell me i have to drop the tank to check the pump
it was running fine, then i replaced an injector seal and now it wont flow any fuel
Sinister Sleeper 35
SpeedRacer
Postby Lloyd » Mon Jan 08, 2007 10:56 pm
You say you have no fuel leaking out, would this be out the return from the pressure regulator to the tank? See if there is pressure at the fuel rail itself, or to the fuel filter. Have to make sure fuel is actually flowing somewhere in the line before you can decide if the pump is stuffed or not without taking it out
Postby SpeedRacer » Mon Jan 08, 2007 11:07 pm
no fuel anywhere, first (before thinking how fuel rails works) i tried the return line (off fpr) then off the delivery line, then off the the filter. all that is left is between the pump side of the filter and line to pump :S
i kno its unothodox, but it also "sounds" quieter aswell
Sinister Sleeper 35
SpeedRacer
Postby Psycho_Dad » Mon Jan 08, 2007 11:08 pm
crack the nut on the fuel filter, see if fuel leaks out their, if no fuel leaks out their, check that you have fuel in the fuel tank
if theirs no fuel just before the fuel filter(crack the bottom nut on the fuel filter) then either your fuel pump has died(kinda unlikely) or theirs a blockage somewhere else
it doesnt make sense for the fuel to just not be thier, perhaps check for power to the pump
admittedly im just a noob, but fuel systems are fairly logical and simple things
good luck
Psycho_Dad
Psycho_Dad
Postby bluemaumau » Mon Jan 08, 2007 11:12 pm
crak the nut a pyshco dad says. chek fuel, chek power
Postby SpeedRacer » Mon Jan 08, 2007 11:12 pm
1/4 of a tank of gas, another reason why i dont want to drop the tank :(
power should be sweet, i can hear it running
Sinister Sleeper 35
SpeedRacer
Postby bluemaumau » Mon Jan 08, 2007 11:14 pm
crak the nut then. just a little, see if it spews out
Postby solitaire » Mon Jan 08, 2007 11:16 pm
if its quieter wouldnt that be likely to be it straining against a blockage?
AE92, KZJ120, KDJ120
solitaire
Postby SpeedRacer » Mon Jan 08, 2007 11:17 pm
SpeedRacer wrote: first (before thinking how fuel rails works) i tried the return line (off fpr) then off the delivery line, then off the the filter. all that is left is between the pump side of the filter and line to pump :S
Already done that
Sinister Sleeper 35
SpeedRacer
Postby Psycho_Dad » Mon Jan 08, 2007 11:30 pm
so you have cracked the bottom nut on the filter? the nut between the filter and the fuelpump? so its obvious that the filter isnt where the blockage may be
ok this is what you do now
crack the bottom nut again on the filter, take that line, put it in your mouth, and see if you can suck the fuel out of it...
the 4age pumps have like a 1 way valve, you cant blow through the pump, but you can suck stuff out of it(unless theirs a blockage in the line)
open your fuel cap before you do it to equalise the preasure
it sounds like a dumb idea, but if it were my car, and my dyno day, id be sucking it like i was trying to suck a golfball through a garden hose
good luck
Psycho_Dad
Psycho_Dad
Postby SpeedRacer » Mon Jan 08, 2007 11:34 pm
dnt worry wen i get the nut off id ill suck it like anything (xcept cock :lol: ) fuel pump is a walbro job but im pretty sure i can still suck thru it
Sinister Sleeper 35
SpeedRacer
Postby solitaire » Mon Jan 08, 2007 11:34 pm
good tip about the 1 way valve mate =)
solitaire
Postby SpeedRacer » Tue Jan 09, 2007 2:43 am
well couldnt get the bottom nut off, but with a couple of turns of the key to prime the line and a quick prayer (actually did pray) it cleared itself :? so heres hoping its going to be ok. runs ok
-Speed
Sinister Sleeper 35
SpeedRacer
