headlight strengths
headlight strengths
Postby nandor markos » Thu Jan 11, 2007 3:10 pm
i have just taken my kp61 starlet for a warrant and i was told the one headlight was weaker then the other, i was told this could be caused by a voltage drop, i have checked out the wiring and some of it looks a bit dodgy but cant see anything that would cause this problem.
just wanting to know if there could be an easy answer as in the bulb is screwed or if it would be something a bit more complicated
nandor markos
Postby l1ttle_d3vil » Thu Jan 11, 2007 3:35 pm
are both the bulbs of the same watts?
all i did was....
Postby TOYROTA » Thu Jan 11, 2007 4:28 pm
all i did was change my sealed beams to semi sealed 91 hilux and got the arctic blue bulbs.
they go strait in
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby Ae92typeX » Thu Jan 11, 2007 6:09 pm
check all wires are in good nick, clean and secure.
Ae92typeX
Postby darkwolf » Fri Jan 12, 2007 2:50 am
When you say you've checked them, does that mean a once over with your eyes or actually running them through a multimeter to check the resistance. Also check things like corrosion on the connectors or marks on the bulb where someone has touched it with their grubby fingers. Remember if you touch it, it'll go blind :P
darkwolf
Postby johntramp » Fri Jan 12, 2007 3:08 am
iv run relays and 'bout 6 gauge wire for my lights, made a massive improvement even with the same bulbs.
johntramp
Postby nandor markos » Sun Jan 14, 2007 8:03 pm
thanks for the info, i just swapped it with another standard bulb and it seemed to do the trick, and also check all the wires with a multi meter just to be on the safe side and as rugged as the wiring is it all works
nandor markos
