This PDF is the instructions on how to make your tacho work when putting a 4agze into a car that wasnt factory equipped with DLI
http://www.rollamods.com/tech/ae86gzetacho.pdf
damogze wrote:Cheapest way is to get your tach re-calibrated to 2 cylinder and hook up tacho to neg. of one of the coils.
matt dunn wrote:damogze wrote:Cheapest way is to get your tach re-calibrated to 2 cylinder and hook up tacho to neg. of one of the coils.
No cheapest way is to just hook up the two wires that are already there
The tacho wire and the output from the igniter that goes to the ig- in the diagnostic connector
