5sgte hybrid ?
5sgte hybrid ?
Postby matty_j24 » Thu Jan 11, 2007 10:21 pm
hey is it possible to take a 5sgte crank and rods and use them with a 3sgte pistons and block etc we have just finished making a 5efte for my dads starlet and was wondering if the same sort of principals would apply would they take boost etc(to a certain extent) any info appreciated
matty_j24
Postby IH8TEC » Thu Jan 11, 2007 10:30 pm
there is such thing as a 5sgte :? :?:
Postby matty_j24 » Thu Jan 11, 2007 10:38 pm
out of what?
matty_j24
Postby matty_j24 » Thu Jan 11, 2007 10:39 pm
thats what im trying to find out can it be done ? its and s series block was wondering if the only difference between the two would be the stroke makeing the 5s a 2.2 as apposed to the 3s being the 2.0 and if it would be just like doing the 5efte hybrid
matty_j24
Postby Dell'Orto » Thu Jan 11, 2007 11:07 pm
Have a look at http://www.mr2oc.com - some 5SFE hybrids there IIRC
Postby Akane » Fri Jan 12, 2007 5:20 am
I think he's trying to use the 5S-FE block mated to 3S-GTE head, which has been done to death in the US, and it works quite well. Check MR2OC.
Postby Adydas » Fri Jan 12, 2007 8:13 am
whats so spech about a 5sfe..
Adydas
Postby Akane » Fri Jan 12, 2007 8:30 am
Well it's 2.2L, it's rumoured to have a strong forged crank, and also rumoured to have a stronger block casing (doesn't crack like Gen 3).
recipe for some mega power.
