blacktop loom > 16v loom
Postby Cakky » Fri Jan 12, 2007 5:40 pm
Ok so doing the blacktop conversion, am getting a full loom and ecu to go with it, a guy I know knows a guy ( lol ) that will take my 16v loom and the 20v loom, remove all unnecessary stuff and rewire them together so that everything is easily plugged and put back in, however I feel this might cost a bit
is this going to be the best option in terms of reliabilty in the long run? what problems should I be aware of? also any other problems in general that I should be aware of in this conversion ae92 gt corolla 16v redtop bigport > 20v blacktop
cheers.
1989 Corolla GT sedan blacktop 20v
Cakky
Postby Ae92typeX » Fri Jan 12, 2007 6:32 pm
as long as the guy knows what he is doing it shouldnt be an issue.
just my opinion, but talking 'long term' the 20v's seem to start burning oil (valve guides?) earlier than 16v's of same mileage.
Ae92typeX
Postby flygt4 » Fri Jan 12, 2007 6:40 pm
time to be concerned with a 20v is when it isnt burning oil. it probly means there isnt any left :lol:
flygt4
Postby Cakky » Fri Jan 12, 2007 9:03 pm
my 16vs pretty stuffed now so thats why i'm swapping
headgasket went, fixed that, then waterpump, then thermostat, so its pretty stuffed by now.
i want to stay n/a and i like the blacktop engine in its n/a form, i've heard most 4ages burn a bit of oil anyway?
Cakky
Postby flygt4 » Fri Jan 12, 2007 9:16 pm
yeah its just normal running, as long as it isnt shitloads. will burn more the more you rev it too.
flygt4
Postby sergei » Fri Jan 12, 2007 9:39 pm
Oil cooler somewhat stops it from burning oil that much. Or use thicker oil ;).
Postby Cakky » Fri Jan 12, 2007 11:39 pm
do you think my clutch will handle the extra power? its relatively new if that makes any difference lol, i'm sure the gearbox will?
Cakky
Postby johntramp » Sat Jan 13, 2007 4:59 am
Cakky wrote:do you think my clutch will handle the extra power? its relatively new if that makes any difference lol, i'm sure the gearbox will?
depends if you know how to drive or not
johntramp
Postby flygt4 » Sat Jan 13, 2007 8:21 am
difference between 16v and 20v in epower realy isnt that much.
flygt4
Postby TRD_ZERO » Sat Jan 13, 2007 10:08 am
Yeah the blacktop isnt all that impressive but its still pretty good, ive got an oil cooler and it still loves to burn oil. Once those valve guide seals are gone its just gona keep burining until you replace them.
TRD_ZERO
Postby Mr Revhead » Sat Jan 13, 2007 10:49 am
huge difference between 16v and 20v.....
your clutch wont fit the blacktop flywheel.
get a new blacktop clutch
Postby Distrb » Sat Jan 13, 2007 11:20 am
you doing this conversion yourself? or paying someone to do it
Distrb
Regular Poster
Postby Cakky » Sun Jan 14, 2007 12:03 pm
Me and my friend were planning on attempting most of the mounting and the engine ourselves, he's done a conversion on his car which was an AE111 4AFE to 4AGE blacktop 20v, i'm not that mechanically inclined myself but its mainly the wiring I am worried about. Thought we can maybe just get people to help along the way with the pieces we don't know about.
You keen on helping Andrew? Maybe we can set up a Wellington meet, help Cakky put in his engine day, i'll put on pizza and booze lol
Cakky
Postby Rob_GTZ » Sun Jan 14, 2007 5:47 pm
I've been doing this conversion for a mate over the past two Sundays, Blacktop into AE92 GT Sedan. Basically all is done apart from the wiring, & i've got both the looms spread out in my garage just going through them at the moment. Haven't struck too many issues, just Blacktop headers don't clear the stater motor if you're using AE92 g/box, but no biggy to modify, just gotta trim off a bracket on the bottom. There was a couple of other things, but i just can't think of them right now
Rob_GTZ
Re: blacktop loom > 16v loom
Postby Caveman » Sun Jan 14, 2007 9:08 pm
Cakky wrote:Ok so doing the blacktop conversion, am getting a full loom and ecu to go with it, a guy I know knows a guy ( lol ) that will take my 16v loom and the 20v loom, remove all unnecessary stuff and rewire them together so that everything is easily plugged and put back in, however I feel this might cost a bit
cheers.
Thats the best way to do the loom, take them both apart, remove and add to make the new engine run. Injector plugs could be different, ignitor, ecu plugs, etc. I just add wires required then reuse a lot of them onto the new ecu plug so it will plug into the ecu.
It may be expensive but its the price to get the job done. If you want to do it yourself arm yourself with both wiring diagrams for the two motors and give yourself atleast a full weekend and a large working area.
Hope this helps
AW11 Track Toy
Formerly known as 1998
Caveman
