ae111 black top clutch replacement
Postby deaf_rattle » Sat Jan 13, 2007 11:02 pm
My g/fs friend has been quoted $750 to have her clutch replaced in her ae111 trueno with blacktop 20v?
Id rather not have to do another clutch job, but i suspect i might have to.
That quote was from pitstop and i have heard that they charge the earth.
Has anyone paid for a clutch replacement for one of these?
I did the silvertop 20v clutch in my ae92 and that took me 5.5hrs with abit of assing about and going off to get bits.
i would expect to be much faster the second time round.
Any prices or info would be great
Postby Rick » Sat Jan 13, 2007 11:32 pm
$300-$350 for clutch kit
I think revhead can do the clutch kits for just under $300 so if you dont do the job yourself, you could supply the clutch to save abit of money.
Postby AceSniper » Sun Jan 14, 2007 1:48 am
with my old engine I gota clutch done, $200 for full kit, $160 labour, but alot of workshops seam to over charge for it or there dum an take ages?
AceSniper
Postby Flunk » Sun Jan 14, 2007 8:24 am
i got an exedy heavy duty kit for mine, $399 if i remember rightly, when i did it last. fitted it myself though.
Flunk
Postby deaf_rattle » Sun Jan 14, 2007 9:00 am
my exeedy clutch kit for the silvertop cost me $170, i would assume same clutch as black top?
i did think we could supply workshop to do it. as far as im concerned, if i could do my first one in 5.5hrs they should be able to do it in 4hrs at the most (should be less) so at 50-70 an hour should only cost about 300 in labour
Check
Postby andyztouring » Sun Jan 14, 2007 9:25 am
If you are putting a standard clutch in ,check prices at partmaster,can be very sharp on their prices.Don`t get clutch plates with rubber blocks instead of metal springs.the rubber blocks go hard and cause bad shuddering on takeoff.
andyztouring
Postby Ae92typeX » Sun Jan 14, 2007 9:45 am
toyota quoted my ae92 about that years ago(~$700), when I was to busy to do myself. Ended up having a girlfriends dads mechanic do it for about $350 including parts.
Not an unrealistic price, but perhaps shop around a little more.
Ae92typeX
Postby Mr Revhead » Sun Jan 14, 2007 10:14 am
yeah thats a bit steep.
iirc i do blacktop kit for $195 delivered. (250+gst rrp)
its a 3 hour job
so even at our full rates its only around $550
Postby TRD_ZERO » Sun Jan 14, 2007 12:29 pm
Id reccomend getting the clutch kit from trade parts the are pretty well priced. I got my exedy clutch plate only, for $78 funny though they make one for a ae92 gtz box that fits the blacktop flywheel, anyway try them.
TRD_ZERO
Postby xRyanx » Sun Jan 14, 2007 7:16 pm
Either way your doing better than me. I got mine replaced recently and also 5th gear syncro, and was charged $1300
Daylight robbery, but that will teach me not to shop around. :oops:
ADMIN EDIT: oversized sig image removed - way too large
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $&#$% UP XRYANX!!
xRyanx
Postby Flunk » Sun Jan 14, 2007 8:33 pm
deaf_rattle wrote:my exeedy clutch kit for the silvertop cost me $170, i would assume same clutch as black top?
thats for a standard. mines heavy duty.. like double or triple plate or something, cant remember exactly.
Flunk
Postby flygt4 » Sun Jan 14, 2007 8:41 pm
it wont be double or triple plate :?
will probly have slightly more clamping pressure and better friction material if anything.
while i was shopping for my new clutch, a clutch place that can test clamping pressure also told me a lot of supposed aftermarket kits use standard pressure plates and claim they are upgraded.
flygt4
Postby Flunk » Sun Jan 14, 2007 9:44 pm
did some research..sorry, the old clutch was twin plate... this is the clutch im running currently:
http://www.exedyusa.com/oe/16950
Edit: Am looking at a Giken double/triple plate for the next replacement... am yet to decide if thier worth the $$...
Flunk
Postby Mr Revhead » Sun Jan 14, 2007 9:54 pm
dude... read the specs....
Postby Flunk » Sun Jan 14, 2007 9:55 pm
Mr Revhead wrote:dude... read the specs....
eh?
Flunk
Postby big_boy » Sun Jan 14, 2007 9:59 pm
this bit
Specs
Number of Discs SINGLE
Thin / Thick Thin
big_boy
Postby Dell'Orto » Sun Jan 14, 2007 9:59 pm
Its stage 2, not twin plate ;)
Postby Caveman » Sun Jan 14, 2007 10:42 pm
Flunk wrote:did some research..sorry, the old clutch was twin plate... this is the clutch im running currently:
$399 is a sharp price for one of those clutchs.
partmaster at trade is approx $80 for a plate and $180 for a full kit. They usually supply exedy. When you shop around for quotes ask for price with supplied clutch and for them to supply it. It might work out cheaper to get them to supply it.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby groupagt4 » Mon Jan 15, 2007 8:18 am
haha your lucky 1700 to do the gt4 clutch
groupagt4
