Engine Oil Coolers...
Postby 2jayzgte » Tue Jan 16, 2007 7:03 pm
Hey guys,
I am doing a FMIC upgrade to my Supra and want to run after market oil cooler as the FMIC is going right in front of the radiator so I figure a engine oil cooler is going to help big time with cooling.My question is that what size oil cooler should I get as I no TRUST and BLITZ do 10 and 16 row kits so Im figuring something along those lines but some feedback would be great.My friend runs a 20 row in his but I've been told not to go to big can someone explain to me why.Any other constructive comments would be great...
Cheers 2jayzgte........ :D
2jayzgte
Postby AE82 FXGT » Tue Jan 16, 2007 9:10 pm
Big ones aren't an issue if you get one of those ones that have a thermostat in them. The oil has to be at operating temperature, and you don't want to over cool it.
AE82 FXGT
Postby sergei » Tue Jan 16, 2007 10:47 pm
What is wrong with "over cooling" oil, it is highly unlikely that you will have -30 outside? I have ran 16row cooler on my Trueno without oil thermostat for about ~100000kms with no problems like sludging or premature wear, as long as the car warms up and thermostat in the cooling system present and functioning the parts will have temperature very close to coolant temp. Infact my 20v stopped typical 20valve burning oil after I installed oil cooler. I would think pistons would benefit from slightly colder oil cooling them (oil squirters) and thus will reduce detonation. Oh yeah the car sometimes sees 9krpm. Also it has 230000kms on the clock. So far I have not seen any side effects in having oil "too cold" (probably never is).
Postby 2jayzgte » Mon Jan 29, 2007 6:24 pm
I am just wondering some good reputable brands of oil coolers to look at I know all the JDM brands HKS,Blitz,Trust and what not just wondering if there are some others that are as good closer to home.Another thing I don't mind spending a little bit more money for quality..
Cheers 2jayzgte.... :D
2jayzgte
Postby sergei » Mon Jan 29, 2007 6:44 pm
2jayzgte wrote:I am just wondering some good reputable brands of oil coolers to look at I know all the JDM brands HKS,Blitz,Trust and what not just wondering if there are some others that are as good closer to home.Another thing I don't mind spending a little bit more money for quality..
I recommend using steel braided hoses. They are much stronger and don't collapse. Also they come with much better connectors. Pushlock fittings are crap.
Postby 2jayzgte » Mon Jan 29, 2007 8:08 pm
Sergei,
Cheers for the feed-back I am going with the good fittings and braided hose's.How about brands of coolers any idea's I had a look at a drivetech 16 row today.As for size of cooler I spoke to my friend who mechanics on a V8 tourer he said the bigger the better as long as you get a good flow of air on the cooler bigger is better....
Cheers again 2jayzgte... :D
2jayzgte
Postby bluemaumau » Mon Jan 29, 2007 8:28 pm
could someone put up the approx price of setting up an oil cooler on a atandard block, read: everthing needed
Postby sergei » Mon Jan 29, 2007 10:28 pm
about $800 give or take: oil filter adapter, oil filter relocator, hoses, fittings, oil cooler.
Postby big_boy » Mon Jan 29, 2007 10:39 pm
mine was
cooler $95 (its a 3 swill coller with 300*400mm fins & a 3/4" flow pipe)
samwedge plate $140 (its the one with the filter on top of it that lets the oil go just thro the filter till 74`c then dervirts it thro the cooler)
drain fitting $45 (its a help at oil changes trust me)
hoses $250 (made to fit by the ENZED man steel braded 1/2"ID with olive & nut fittings)
gauges block $55 (yeah i know you might not need/want this 1 but i did )
for sale EE90
big_boy
