barryogen wrote:there is one in the UK... I have a video of it beating some very expensive cars in a drag or two. from memory they said it cost them ~30000 pounds, but it was also 600 and something HP
soopachargen wrote:haha i like the way you think... is the 4wd model manual??
barryogen wrote:Incidentally, the 2zzge, although it has a fair bit more HP, it has only 5% higher torque than the 1zzfe, and it is at ~double the revs of the 1zz... so on a track with the right drivers, it should make 2/5s of f**k all difference. The 1zz has a nicer torque curve too from memory.
Punter wrote:The car with more HP will be faster, no ifs or buts about it.
um in a word... no
Your talking as though torque and power are not directly related.barryogen wrote:not exactly the same... but it was the only two cars I could find with similar specs HP wise but miles apart torque wise.
so a Honda B18CR with some cam work doing ~200HP at 9000RPM and ~200NM torque and a WRX at about the same HP, but 330NM torque, taking traction issues out of the equation.
You think that the Honda would be quicker round a track?
Actually, they would be close(not too close though), but I'd give it to the Subaru by 5% of the track distance.
Punter wrote:Your talking as though torque and power are not directly related.
Huh?thaphatty wrote:Punter wrote:Your talking as though torque and power are not directly related.
Theres no difference! all horsepower is is an idication of where/ how much torque you've got avalible in your rev range for your gearing to work with
