RunningRich wrote:The easy way is to use a two pillar hoist. Believe it or not the engine and gearbox (which you don't separate in the car unless really stupid) drop out very easy using a block and tackle, but the car must be dead level. If not level you will end up fighting with the engine mounts, firewall, steering rack etc etc.
Last time I did this the two of us had the clutch and flywheel out 2-1/2 hours after driving the ST165 into the workshop.
If you use and engine crane and lift the car over the engine you are in for a world of trouble, as I have learned too many times...
Leave the loom on the engine, disconnect it from the ECU, not difficult.
Infinite wrote:in the curren i drop it in and out thru the top, takes me about 3 hours to take out and put back in :p ive had some practice lol and i do it by my self on a engine crange
