1JZ Coolant Leak
1JZ Coolant Leak
Postby Si » Fri Feb 02, 2007 10:45 pm
After going for a drive the other night, saw steam comming from the bonnet...
Stopped and found water leaking :( . Got car back into town etc etc. Had a look and found a split heater hose. replaced heater hose.
Filled car up with water again and started. And the thing still pours water all over the ground!
After a couple of hours digging around the back of the block i find what appears to be the leak. there is a metal pipe that runs from thee water pump, down the drivers side of the block, around the back of the block to half way up the other side! the pipe must have a crack or pin-hole in it. (Cant feel any damage with my fingers)
from a pic when doing my clutch, this is what the pipe is i think
now the ways of fixing it i see are either removing the gbox and cutting the pipe out and joining a replacement bit in. or removing the pipe it self. removing the pipe itself would involve removing of the intake manifold and the turbos etc. of the two options both are a bitch.
Just fixing the leak wouldnt check the rest of the pipe for damage... which could be bad later on.
Anyone had anything else similar happen, or know what causes it?
Or can suggest a alternative way of fixing it?
Current: , '96 SubaruImpreza
Si
Postby MrOizo » Sat Feb 03, 2007 11:24 am
have you taken the engine out at all?
MrOizo
Toyspeed Legend
Postby Si » Sat Feb 03, 2007 12:29 pm
Nope not at all
Si
Postby Si » Sat Feb 03, 2007 9:02 pm
Theres the pipe, in yellow. its all one bloody piece!
It makes me want to cry. There is very little way that engine is comming out without a hoist (or angle grinder)
im tempted to use radiator leak fixer stuff. but yeah not sure on that
Si
Postby MrOizo » Sat Feb 03, 2007 9:24 pm
if you use that then next time i'm down them ways i will guarantee that i will slap you silly with what ever is in reach :?
If i was closer, i would mind giving a had to remove the engine. i like to think i have that down to an art :P
Might be better to just get a new part or if too much and no can do, then taking it out and having it welded up will have to be the go-er.
Waas hoping it was something stupid a clamp not being put back on from the engine being removed (just like i did :oops: )
Where in Palmy are you based anyways?
MrOizo
Toyspeed Legend
Postby Si » Sat Feb 03, 2007 9:40 pm
In Palmy around the terrace end of town, similar area to mmmboost.
looks like the engine needs to come out, which is a pain but oh well.
maybe I should bite the bullet and go big single hehehe
Si
Postby MrOizo » Sat Feb 03, 2007 10:44 pm
Might as well :)
thatts the pipe that backs onto the water pump isnt it? i have one here and its not that long:o
MrOizo
Toyspeed Legend
Postby Si » Sat Feb 03, 2007 10:47 pm
not really in a financial position to do so however :(
the pipe is colored a creamy color in the diagram above, it all looks like one peice so i assume it is.
Runs under the turbos around the block and under the intake manifold.
What tricks are there to removing the 1j? turbos on or off?
Si
Postby MrOizo » Mon Feb 05, 2007 7:26 pm
lifting all out in one.
as long as you have a engine hoist you should be fiiiiine
taking the turbos off is such a biiiitch if the engine us still in the car :o
MrOizo
Toyspeed Legend
Postby Si » Tue Feb 06, 2007 12:43 pm
Okay cool,
now, does the gearbox need to come out, or can the clutch just be unbolted from the flywheel and the gbox left in place while the engine is remobed?
Si
Postby MrOizo » Wed Feb 07, 2007 12:39 pm
alllll out in one go is the way :)
basically disconnect/unbolt everything from the chassis and remove.
might wanna get a hold of the bgb or (similar) or something like cygnusx1 - http://cygnusx1.net/Supra/Library/TSRM/MK3/for removing engine. its based on the 7m but you get the idea on what needs to be removed and all that :)
MrOizo
Toyspeed Legend
Postby Bling » Wed Feb 07, 2007 9:33 pm
this post may be useless... but
can you cut it where shown and re-route it somehow?
including the pipe that T's off near the firewall (if i'm viewing it correct)
Postby spencer » Wed Feb 07, 2007 9:37 pm
this pipe feeds into the sandwhich plate behind the oil filter(oil cooler) then into the block no re-routing to be done
ms63 crown
spencer
Postby Si » Thu Feb 08, 2007 8:24 am
Thats a pain in the ass, who ever made the exhaust didnt put any flanges in. so its one length. and of course the exhaust bolts to the gearbox!
Pain in ass!!!!
so far i have the radiator etc out, intercooler piping out, and now started on the wiring loom.
very very tempted to go to the bank and get 10k and have some fun and games :)
Si
Postby Silent Knight » Thu Feb 08, 2007 9:26 am
If it's just leaking from a certain spot on the pipe can't you just cut the pipe and put some high temp tube over it and clip it on?
Silent Knight
Postby Si » Thu Feb 08, 2007 7:35 pm
I could if i could get my hand in there!
Even if i did it wouldnt alow me to check the rest of the pipe for cracks etc
Si
Postby MrOizo » Thu Feb 15, 2007 10:23 am
Si, hows this coming along? :O
MrOizo
Toyspeed Legend
Postby Si » Thu Feb 15, 2007 12:57 pm
no more since about a week ago.
Landlord decided that a flat inspection was needed, so had to clean up. had planned to do more this week and next week but im in wellington for training till the 26th of feb...
Might be a long road to get this one done!
Si
