Wiring up a tacho, how to do?
Postby ollieboy » Sat Feb 03, 2007 2:13 pm
In a diesel, is it even possible with a normal tacho?
Ollie
ollieboy
Postby slighty_sykotic » Sat Feb 03, 2007 2:24 pm
dangly wire to negitive coil.
Bout as good as your going to get without any details :?
--Sykotic
slighty_sykotic
Postby ollieboy » Sat Feb 03, 2007 2:43 pm
But theres no coil.
ollieboy
Postby slighty_sykotic » Sat Feb 03, 2007 2:59 pm
and that is true.....
Umm, surly there is a tmiing signal of some sorts.
Whats the car? Checked the ecu pinouts for the motor?
Does it use a cam angle sensor? if so, what type?
slighty_sykotic
Postby ollieboy » Sat Feb 03, 2007 3:12 pm
Its an r31 skyline with a 3 litre diesel.
Not sure about what you ask but will check sometime in the next week, Car is at home and I'm not so will check when I get back.
ollieboy
Postby matt dunn » Sat Feb 03, 2007 7:02 pm
There is a Diesil tacho interface available to run a wire out of the alternator into the interface and out to a tacho.
They are only as accurate as you calibrate it to be,
so to be really accurate you need to get them set of a proper diesil tacho ( that runs off pressure pulses in the fuel line)
or an optical tacho.
So
Q. In a diesel, is it even possible with a normal tacho?
A. Yes but expensive and difficult.
