turbo 4agte where to start
Postby XXL » Mon Feb 12, 2007 7:30 pm
hey guys hows it going? i have a few questions about setting up my big port red top with a tubro. i am pretty new to the whole dohc turbo set up i have had all old pushrod motors and so iam kind of ignorant on where to start. i have read a few of the posts about 4agtes but still a bit confused on it all
i do not have the money to do an azge transplant and stripping my block and doing forged internals is out if my budget to, but on the bright side i have a new turbo mainfold and a really tidy T3 for it.
i guess I want to know what problems i will have if i try to set it up with stock internal running only 6psi boost. also whats an easy way to lower my comp down. also what needs to be done with the ecu
am i just wasting my time. i would like to be able to drive it for a while with out putting a rod out the side of the block
anyway any advice is helpful
cheers XXL
XXL
Postby Bling » Mon Feb 12, 2007 7:53 pm
have a search for 4agte and 4age turbo etc, many people have done it with different methods so with a bit of a search you'll get a good idea of whats ahead of you :)
Postby no_8wire » Mon Feb 12, 2007 9:52 pm
no_8wire
Postby Crampy » Mon Feb 12, 2007 10:17 pm
I'll be getting pretty much the same thing going as you very shortly. I've got a stock bigport Redtop, which is going to be turboed. I'm still running stock ECU and base engine, but doing a few other mods to get it running. Give me a PM and I'll let you know what I've done and give it another maybe month and I'll let you know how it all goes.
Crampy
Postby AE25 » Sun Feb 18, 2007 1:03 am
some things to think about... and going on other people's experiences + logic here... (im *yet* to build 4agte)
putting a turbo on a std 4age, stock efi system is asking for trouble as the ignition and fueling is tuned for n/a and compression too high for reasonable boost. ring lands are usually the first thing to break! running 6psi on stock internals should handle it fine. you can safely run more psi if the efi is tuned to suit. adviseable to use 4agze pistons as are much stronger.
some things to watch out for is putting a turbo on a high km engine.. as the turbo is sucking some of the oil and high k's means worn bearings and low oil pressure, so big end bearing failure is not uncommon. especially on bluetop.
there are many ways to skin a cat
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby matt dunn » Sun Feb 18, 2007 9:16 pm
AE25 wrote:some things to think about... and going on other people's experiences + logic here... (im *yet* to build 4agte)
Most of that is pretty true.
I dont think the amount of oil that a turbo uses will have an effect on the oil pressure to the bearings.
Run bearings are more likely caused by detonation than oil problems unless you get oil surge.
A standard 4AGE will take a turbo no problems with low to meduim boost levels.
6 8 or maybe 10 may even last, but as said above the Timing and Fueling
are the thing that makes it last or go bang.
Matt
Postby XXL » Sun Feb 18, 2007 9:46 pm
cheers guys i have had some great feedback (thanks for the PM crampy) I think i will try the starlet map sensor and agze injectors and see how that works for me i will be a few months away so hopfully you will get yours running Crampy and I will keep an eye out and see if it works ok
cheers a guys
XXL
