oil feed size for a td05?
Postby Psycho_Dad » Wed Feb 14, 2007 7:48 pm
i have a td05 off a subaru
it didnt come with the oil feed line
does anyone know what size restrictor on the oil feed line i should run?
its going on a 4agze engine
i intend on putting a t piece between to block and the oil pressure sensor
any knowledge gladly absorbed
PEace
Psycho_Dad
Psycho_Dad
Postby Crucible » Wed Feb 14, 2007 8:06 pm
I used -3 supply line with 19mm return with a t3/4.
ran the feed line straight from the block to a tee mounted on the chassis rail, then to the turbo.
Bronze tees supposidly crack from heat if screwed straight into the block, thats why I mounted it remotely.
make sure you keep the return high!
Crucible
Real Life Mechanic
Postby no_8wire » Wed Feb 14, 2007 8:50 pm
Sweet...I needed to know this as well...
8)
no_8wire
Postby Psycho_Dad » Thu Feb 15, 2007 5:44 pm
so what exactly is -3 a measurement of?
Psycho_Dad
Psycho_Dad
Postby Crucible » Thu Feb 15, 2007 5:55 pm
Its an american standard of measuring hoses etc, i think they only use it with earls fittings etc because everything else like fuel, heater hosing is in imperial/metric sizing
this is -3 I used on mine to give you a rough idea....
Crucible
Real Life Mechanic
Postby no_8wire » Thu Feb 15, 2007 6:36 pm
So what fittings need to be used?
From the "t" and to the turbo?
no_8wire
Postby Crucible » Thu Feb 15, 2007 9:32 pm
I ran a straight fitting from the tee then a 90deg elbow into the turbo flange, to suit -3 lines, I got enzed to make them up,..... its easier :D
Crucible
Real Life Mechanic
Postby Steve123 » Fri Feb 16, 2007 12:54 am
-3 is the usual for ball bearing. -4 for plain bearing is ok. about 2mm.
Steve123
Postby no_8wire » Sun Feb 18, 2007 2:17 pm
-4 ok? But not optimal?
no_8wire
