cressida- 5M-GE
cressida- 5M-GE
Postby NOLAW » Thu Feb 15, 2007 7:30 am
if a cressida has a 5M-GE in it and i was just wondering does this mean a 7M-GE/GTE will bolt in onto standard Xmember and mounts?
NOLAW
Postby Anth_555 » Thu Feb 15, 2007 7:39 am
yip you will need the sump off the 5m too
-1994 GT4 Celica ST205 project
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby deaf_rattle » Thu Feb 15, 2007 9:00 am
add me to your msn and ill talk to you about the swap tonight if you like...
Re: cressida- 5M-GE
Postby Toymad » Thu Feb 15, 2007 10:35 am
NOLAW wrote:if a cressida has a 5M-GE in it and i was just wondering does this mean a 7M-GE/GTE will bolt in onto standard Xmember and mounts?
Anth_555 wrote:yip you will need the sump off the 5m too
And add to that the 5M oil pump/oil pickup, or modify the 7M's oil pickup. Then, you'll need to consider the oil dipstick - the 7M unit is set up for the "mid sump" arrangement, but you will be using a "front sump" from the 5M. When I did this swap, I had a 90 degree bend welded to the passenger side of the sump (below the oil level and made a new dipstick tube to suit.
Be aware that 7Ms are prone to bearing failure if you get low on oil. I made my setup with a little extra so that "LOW" was the normal mid point.
David
Toymad
