matt dunn wrote:you do realise that just because the crank pulley is at TDC does not mean that the engine it at TDC no 1 cylinder,
as it may be at TDC on no 4 cylinder.
you may have had it 180 deg out.
Either re do it at tdc again an if it doesn't go,
rotate the crank 360 so the rotor now points at no. 4
Then take out the dist and spin it 180 and refit.
Then it should go.
Or read this and do it by looking into the oil filler hole.
Matt
slighty_sykotic wrote:option two is wrong. flat out wrong.
I would do option one, and then move the dizzy, if it doesnt go far enough, then its a tooth (or more) out.
--Sykotic
KinLoud wrote:Are you using the factory computer?
To set the timing...
Put a jumper wire across the correct connectors on the diagnosis plug (let me know if you don't have one that is obvious)
Make very sure that the throttle is completely closed - hold it closed if you need to. This is so the throttle position switch tells the computer it is closed. The little idle up bellows thing below the throttle stop tries to push it a bit open and so the computer won't spark at the right place so you can't set 10 degrees basic timing.
Also - the dizzy should be set to number 1 when the crank is at 10 degrees not 0.
Ken
Ham
021 408 863
