whats this? e series
Postby bluemaumau » Sat Feb 17, 2007 6:23 pm
so trying to mount my gearbox up today i put the half shaft on the raer of the block to make it harder for myself :lol:
i lifted the e58 ae101 gtz lsd box up and i didnt get it on
as i was removing the box this little ring was left hanging on the spline of my halfshaft
description: its like a tightly wound spring making up a ring, it is about 45mm in diaqmeter
pics;
it comes from here:
1: so what is it?
2: do i need it?
3: how the $&#$% do i get it back in?
4: were does it go!?
Postby sergei » Sat Feb 17, 2007 6:33 pm
That looks like spring from seal.
If I were you I would just buy new seal...
Postby flygt4 » Sat Feb 17, 2007 7:38 pm
LOL at spare parts :lol:
flygt4
Postby slighty_sykotic » Sat Feb 17, 2007 8:05 pm
Yeah, i agree with sergei.
100% sure thats the spring from inside the oil seal on the drive shaft.
Take the shaft off the block and put it on after, you should get it on easy enough.
But yeah, through the axle oil seal away and get a new one.
--Sykotic
slighty_sykotic
Postby thegreatestben » Sat Feb 17, 2007 10:47 pm
thats definately the spring from the seal
thegreatestben
Postby slighty_sykotic » Sat Feb 17, 2007 11:02 pm
Im gald you agree with with me!
slighty_sykotic
Postby The_Lorax » Sun Feb 18, 2007 12:15 pm
Yep, it's the spring from the seal.
The seal is cheap to replace, so might as well do it. Leaking gearboxes suck, and you need the spring to seal it properly.
The_Lorax
Postby bluemaumau » Sun Feb 18, 2007 7:03 pm
bnt? the place to go?
ask for a e58 gearbox driveshaft oil seal???
cheers everyone
