87 hiace highbeams not working?
Postby 20vtoylevin » Mon Feb 19, 2007 7:16 pm
fuse is fine, the lights are sealed so unable to check bulbs etc...
any other ways to check? both of them don't work on highbeam but both work on low beam?
any help is good help?
blah
20vtoylevin
Postby AE82 FXGT » Mon Feb 19, 2007 7:35 pm
Checked relays?
AE82 FXGT
Postby fangsport » Mon Feb 19, 2007 8:27 pm
switch contacts?
real common in Navaras of same vintage
fangsport
Postby crispy'86 » Mon Feb 19, 2007 9:16 pm
check the switch contacts and the relays, we had trouble with same thing on a hiace, and aldo check for power at relay blocks, and plug where it goes into the headlight unit
crispy'86
Postby skoty » Mon Feb 19, 2007 9:24 pm
My moneys on the combination switch also.
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby solidog » Tue Feb 20, 2007 1:59 am
you should be able to get one from the wreckers anything from $50-100, easy as replacement, but do it yourself rather then pay someone $$$ in labour! take the covers off the steering column and unplug the connetor blocks attached to the h/l indicator stalk (should be a couple, or 1 big one). if your lucky you will be able to unscrew it without taking your steeringwheel off, if you do be sure to mark it out before removing it!!!! lol or u'll be steering wonky and they can be fiddly to re-center!
-=4age inside ~ Allmotor Toyota=-
I know stuff, im modest, I get involved
Yeah newtown ae that me! Did you know "Newtown : Its a bit shit!" but not me!
solidog
