Norty wrote:*update* was alot quieter this morning, either it was camera shy, or maybe a good drive last night and that oil filter finally got things moving, and whats left is just damage.
postfach wrote:Norty wrote:*update* was alot quieter this morning, either it was camera shy, or maybe a good drive last night and that oil filter finally got things moving, and whats left is just damage.
when you changed the filter did you change the oil also? if so your previous oil may have been too thin. i used 10w30 on my engine last time and got a bad case of the knocks when cold starting, changed to 15w40 this time and it has almost completely gone.
Toymota wrote:The sounds that your car makes sounds pretty similar to my ST185. Except it sounded like your car only made it for a few seconds just after it started up. I only remember noticing it making that rattle after I did an oil change on the car only about a week after buying it and putting a Repco filter in.
For me it might just be the filter but I wouldn't be surprised if its the engine because I'm sure its on it's way out.
I thought that the Repco one would be pretty decent seeing as though it costs so much.
Akane wrote:Exactly same as mine, actually mine's a bit louder.
Still goes hard tho
So what I think mine has happened is the water/moisture has gone into the oil and wore out the bearings on the main crank.
