4agze aircon removal options.
Postby tex » Sun Feb 25, 2007 10:47 pm
Did a search and could not find a proper answer.
AE92. 4AGZE. Uses a silly heavy bracket to mounthe PS/aircon and alternator. On that bracket the PS pump is driven off the secondary belt off the aircon pump.
Anyway the car is getting converted to turbo eventaullym but for the interim i need to mount the alt and the ps pump up, but the aircon i have is way too big to fit on the bracket.
Want to ditch the dam aircon anyway cos it sooo heaby and so is the bracket.
I tried using a ps bracket from a 20v and spacing out the pump but then that leave no room for an alternator on the front either (aw11 4azge alt bracket).
What have other ppl used for mounting the PS pump on the exhaust side and what pump did they use??? Was thinking just using a ae101 bracket and pump...?
Still doesn't solve the alt issue but least half way there.
TEX
tex
Postby crispy'86 » Tue Feb 27, 2007 7:02 am
have you thought of running an ae92 p/s bracket, or ae82 fxgt 4age pump bracket??
crispy'86
Postby Barks » Tue Feb 27, 2007 7:56 am
I've got a bracket that I've cut some of the metal out of to lighten it up. The A/C is removed and the P/S has a modified pulley so everything runs off one belt. Worked well, but now it's been ditched as I've gone to an N/A Alt and P/S set-up.
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Barks
Postby thaphatty » Tue Feb 27, 2007 9:01 am
You could try pm'ing Xyrath, I gave him an aw11 p/s bracket a while ago. dont think hes used it
Puts the pump on the right hand side there
thaphatty
Postby tHE _mEXICAN » Tue Feb 27, 2007 9:36 am
yes i too wanted to get rid of the pump and was too going turbo in the future.
I ended up waiting til i had the money for turbo and switched to NA 4age alt, ps pump etc. Its easy, if your gona go down the turbo path you'd prolly need an NA plenum if its in an FWD car otherwise it'll be custom and it'll free up alot of space for manifold/turbo/ehaust clearances.
I'd suggest to just find the right A/C pump as no one really wants em once converting to turbo and use the NA 4age pulley setup once you decide to go turbo as its easy to find parts for and all you really need to make is a PS pump tensioner.Else go all out now and get the setup the turbo, lots more fun I reckon
But its up to you mate
RIDES:
73' KE25 SR Coupe (LONG TERM PROJECT)
Soon to be 4AGTE monster powered
tHE _mEXICAN
Postby tex » Tue Feb 27, 2007 4:29 pm
Thought that would be the case. Currently got a fwd bracket for the PS. Probbaly just gonna chop down the factory gze bracket to attach the allternator. Will solve the problem for the mean time. :)
Thanks
tex
Postby themaleman » Thu Mar 01, 2007 6:55 pm
on mine weve removed the aircon pump and put the alternator on the intake side, welded another pully on the outside of the powerstering pully so its inline with the crank pully. cut the bracket 2 suit, n had 2 modify the p/s line[img][img]http://img218.imageshack.us/img218/82/image478ig3.jpg[/img][/img]
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby matt dunn » Thu Mar 01, 2007 10:34 pm
I have some AW11 GZE brackets from a conversion a while ago.
For the right price I could dig through my boxes of brackets and stuff and find them.
Matt
